UCCX agent desktop action buttons not showing
Answered Question
Hi All,
I've added some custom action buttons to the agent desktop interface to launch external scripts. The buttons show up on most of the agent desktop clients, but there are a small number that won't update to show the extra buttons. On top of that, every new desktop agent I install is also missing the buttons.
Has anyone else run into something similar?
Cheers,
Gary
Correct Answer by Walter Solano about 7 years 3 weeks ago
Hello Gary,
That can be done under the Personnel configuration and if you have UCCX 7 you should go first to site A and after that go the personnel config.
Please rate this post if was helpful
Walter Solano
CCVP, Cisco UCCX Specialist
Cisco IP Communications Express Specialist
Overall Rating: 5 (4 ratings)
Correct Answer
Walter Solano Fri, 07/02/2010 - 14:17
  • Gold, 750 points or more
Hello Gary,
Walter Solano
Walter Solano Fri, 07/02/2010 - 14:26
Walter Solano Fri, 07/02/2010 - 15:05
No problem Gary!!!
Cheers
Walter Solano
Walter Solano Fri, 07/02/2010 - 13:40
Did you try close CAD and reopen it, that needs to be done to apply any changes to a workflow.
Related Content
