Quick test to confirm IPS is working?
Jul 2nd, 2010
Something so simple seem to be difficult to find online anywhere.  We configured IPS on a Cisco ISR 871 and applied it inbound for our WAN and LAN interfaces.
Question is this ... is there a quick IPS test I can do to confirm that the IPS working?
Something like a webpage that has content that would be blocked by one of the IPS signitures.
Thanks in advanced!
-rya
Michael Dombek Fri, 07/02/2010 - 12:57
Basically from what i remember from the IPS trainings enable Signature 2000 or 2004 for ICMP (not sure about that somewhere around these numbers) and try to ping something - if you configured everthing correct this should trigger an allert.
HTH (if so please rate)
cheers Michael
