Static and dropped calls
Jul 2nd, 2010
Hello we just got a complain that incoming calls get static
we have a cucm 6.1.2 cluster of 2 servers and 2811 with a pri locally to remote locations
one of this locations is complaining about static and dropped calls
i was checking the controller of the pri and this is what i saw
otal Data (last 24 hours)
     0 Line Code Violations, 561 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 120 Degraded Mins,
     144 Errored Secs, 69 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
No slips but a couple of errored seconds
also i have the
network-clock-participate wic 2
network-clock-select 1 T1 0/2/0
configured
clocking looks good
Network Clock Configuration
  Priority      Clock Source    Clock State     Clock Type
     1          T1 0/2/0        GOOD            T1
    10          Backplane       GOOD            PLL
  Current Primary Clock Source
     1          T1 0/2/0        GOOD            T1
the router is properly grounded
our PRI carrier is Verizon
do you have an idea of what is causing the problem?
kebrenna Fri, 07/02/2010 - 16:54
For those errors, I would just have the carrier test the circuit.  Looks more like a Verizon issue most likely.
K
