checksum importance
Jul 2nd, 2010
I have a cisco 3620. I just attempted to copy my
Sim flash image to a new 20 MB PMCIA flash
Router#show version
IOS (tm) 3600 Software (C3620-IS-M), Version 12.1(3a)T7,  RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/cgi-bin/ibld/view.pl?i=support
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Sat 10-Mar-01 19:45 by ccai
Image text-base: 0x60008950, data-base: 0x6102E000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (f
c1)
ROM: 3600 Software (C3620-IS-M), Version 12.1(3a)T7,  RELEASE SOFTWARE (fc1)
Router uptime is 1 hour, 11 minutes
System image file is "flash:c3620-is-mz.121-3a.T7"
cisco 3620 (R4700) processor (revision 0x81) with 49152K/16384K bytes of memory.
Processor board ID 29853621
R4700 CPU at 80Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
2 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
20480K bytes of processor board PCMCIA Slot0 flash (Read/Write)
     Size(b)     Free(b)      Type  Flags  Prefixes
       30712       30136     nvram     rw   nvram:
           -           -    opaque     rw   null:
           -           -    opaque     rw   system:
           -           -   network     rw   tftp:
*   16777216     6839256     flash     rw   flash:
    20971520    20971520     flash     rw   slot0:
           -           -     flash     ro   slot1:
           -           -    opaque     wo   lex:
           -           -    opaque     ro   xmodem:
           -           -    opaque     ro   ymodem:
           -           -   network     rw   rcp:
           -           -   network     rw   pram:
           -           -   network     rw   ftp:
So I made the copy command:
Router#copy flash:c3620-is-mz.121-3a.T7 slot0:c3620-is-mz.121-3a.T7
erase n
CCCCC ect.
but the check sum failed
Verifying checksum...  invalid (expected 0xBC40, computed 0x3E95)
9937896 bytes copied in 195.640 secs (50963 bytes/sec)
Router#how version
so dir commands:
Router#dir flash:
Directory of flash:/
  1  -rw-     9937896              <no date>  c3620-is-mz.121-3a.T7
16777216 bytes total (6839256 bytes free)
Router#dir flash0:
Router#
So how important is the checksum here before I move to set the register to boot from the PMCIA card.
Should I reformat erase the PMCIA card andf retry the copy or should I reformat /erase and try maybe copy running config commands instead?
Reza Sharifi Fri, 07/02/2010 - 18:18
  • Cisco Designated VIP,
    2017 LAN
it seems that the copy was done successfully but it would not heard anything if you erase and format the PCMCIA card and copy it again.  The other thing is that if you put the PCMCIA card in its slot and reboot the router it will try to boot from the PCMCIA card first and it can't find the image then it will boot from flash but you have to make sure that the image is on flash and it is working with no issues.
Reza
pheidius12 Fri, 07/02/2010 - 21:18
Ok, I will try it from  the reformat side/recopy first. This was supposedly a new card but you never know. Is there any chance that the simm image will expand slightly diferently in flash memory then Simm? The size in bytes is the same on both cards. I backed up the image before the first copy to my TFTP server plus I have another IOS that I can throw on the hardrive in the worst case. Would a running config  copy be a better comparison as it would already be uncompressed? The router boots and has been running from the simm source with no known issues
Related Content
