VPN CONFIGURATION
Answered Question
Jul 3rd, 2010
Please I am new about the VPN configuration. I have Cisco ASA 5520. How will I know that my Cisco will support VPN.?Is there any additional module  to be inserted ?
thank you and best regards
Correct Answer by JORGE RODRIGUEZ about 6 years 9 months ago
It will support VPNs,  see table for your model , you do not need any  VPN modules  is all integrated . You can also see firewall eabled/disabled  features in output   show version   from firewall  command line .
Models
http://www.cisco.com/en/US/products/ps6120/prod_models_comparison.html
For VPN config exmaples RA or L2l etc..
http://www.cisco.com/en/US/products/ps6120/prod_configuration_examples_list.htmlhttp://www.cisco.com/en/US/partner/products/ps6120/prod_configuration_examples_list.html
I recomend  to see this video introduction of the product to get you started to get overall information of the firewall
http://www.cisco.com/en/US/products/ps6120/index.html
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Sat, 07/03/2010 - 06:06
  • Green, 3000 points or more
Models
ericohermoso Sat, 07/03/2010 - 06:21
I got this info from sh version:
Licensed features for this platform:
Maximum Physical Interfaces  : Unlimited
Maximum VLANs                : 150
Inside Hosts                 : Unlimited
Failover                     : Active/Active
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
Security Contexts            : 2
GTP/GPRS                     : Disabled
VPN Peers                    : 750
WebVPN Peers                 : 2
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
Advanced Endpoint Assessment : Disabled
UC Proxy Sessions            : 2
VPN is enabled, what I do not know is WebVPN : 2. ?
Anyway thank you so much for the reply and all the site information.
JORGE RODRIGUEZ Sat, 07/03/2010 - 07:03
Erico,  you're very welcome..   go over the links, it is alot so  take your time..   if any questions post them and someone in netpro will help.
The Webvpn 2, means that all ASA comes with 2  licensed Web VPN sessions, meaning if you want to use WEBvpn or Annyconnect  VPN you can only have 2 sessions established, if you need to increase the session then you need to purchase licenses for it, which I believe goes by bulks of  25,50,100  etc..
