upgrade co-resident ipcc 6.0 to 6.0SR1
Jul 3rd, 2010
  • Silver, 250 points or more
Iam having a new project CM 4.3(2) installation with IPCC 6.0 co-resident on the same server
I faced a BUG in 4.3(2) call manager which require an upgrade
So I upgraded to CM 4.3(2)SR1b
When starting to install the IPCC,the CRS compatibility matrix states that CM 4.3(2)SR1b is compatible with IPCC 6.0 SR1
So first I'll install IPCC 6.0 on the pub server
Then I have 2-methods for the upgrade to SR1 :
1. Using BARS which I used before with non co-resident CM and IPCC which let the CM send the patch to the IPCC then installing it on the IPCC
2. Unzip the .tar ipcc upgrade file on the CM server and simply press setup.exe and follow the wizard
So Iam asking which one of the 2-methods is the correct one for co-resident CM and IPCC servers ???
