access-list no-nat1 permit esp - and nat (dmz3) 0 -
Jul 3rd, 2010
Dear Friends,
I am having a peculiar problem here. I have a ASA 5520 with VPN plus license. whenever i give a command like
# nat (inside) 0 access-list no-nat
#nat (dmz3) 0 access-list no-nat1
and then
access-list no-nat1 permit esp 172.24.67.16 255.255.255.248 193.113.32.32 255.255.255.224
it says
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
ERROR: ACE contains port, protocol, or deny. Removing NAT configuration
The same configuration was already running in my old pix 525 but is not in the ASA.
Pl help..
Rajiv.
terrygwazdosky Sat, 07/03/2010 - 08:22
On the PIX prior to version 7 you could specify ports and protocols in no-nat ACLs though it showed a warning message.  You'll need to use this syntax:
access-list no-nat1 permit ip 172.24.67.16 255.255.255.248 193.113.32.32 255.255.255.224.
You could always restrict non-esp traffic with an interface ACL if needed.
Please rate posts if you find them helpful.
