Storm Control in the access layer
Jul 3rd, 2010
Have a general question about the implementation of Storm Control in the access layer.
The answer is likely a "it depends" on your environment, but in gerneral what would be a good percentage to start with for implementing storm control in the access layer where end users/end user devices (printers, etc...) connect? Assuming the access switches are a mix of 3550/3560/3750 10/100. I was thinking around 50 percent to start with (for some broadcast storm protection), but was curious to hear from those that have implemented.
Overall Rating: 4 (1 ratings)
Giuseppe Larosa Sat, 07/03/2010 - 12:06
Hello Brandon,
we have used 1% on GE ports with /24 IP subnets
I could guess 10% on FE ports should be fine.
The size of the IP subnet counts
Hope to help
mbroberson1 Sat, 07/03/2010 - 13:00
Hi Giuseppe,
Thanks for the reply. I do appreciate it.
e-montagnino Thu, 07/08/2010 - 07:24
I am also looking into setting up storm/broadcast control and very interested.  We have variously sized subnets as well as supernets.  How exactly would you factor in network size to setup some starting settings?
Thank you.
