How to disable(or shutdown) the echo canceller daughter card (EC-MFT-64) ?
Jul 3rd, 2010
Hello all,
Could the echo canceller daughter card (EC-MFT-64) be disabled (shutdown) by any IOS command?
The  daughter card is seated  in 2-Port RJ-48 Multiflex Trunk - T1/E1 card.
The purpose of doing that is to apply the workaound of bug CSCtg92548.  The workaound is to remove the daughter card from
voice gateway. I am thinking the better way.....
More info. about the echo canceller daughter card, please see:
WIC Slot 1:
        VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
        Hardware Revision        : 0.0
.....(output omitted)
        EM Slot 0:
        H/W Echo Canceller (64 Channel)
        Product (FRU) Number     : EC-MFT-64
Thanks in advance
Paolo Bevilacqua Sun, 07/04/2010 - 10:49
If there was a software workaround, cisco would have indicated that.
Your best course of action is to contact the TAC to find exactly how this bug affects you, and define the next course of action.
master001 Sun, 07/04/2010 - 11:02
thanks for your reply.
I don't see any software workaround from the bug (CSCtg92548)details.     I am just wondering if  I could manually disable the daughter card instead of removing it from the box.....
thanks again.
