WAAS hardware is OE612, but Rescue Disk detects model as OE512
Jul 3rd, 2010
I've had this issue with 2 RMA'd OE612s already. They originally shipped with 4.0.19, which worked fine, but failed on upgrade to 4.2.1.
Recovery attempt #1 with 4.0.19 Rescue disk displayed :
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
   MODEL: UNKNOWN
   FLASH: found, directory validated
  COOKIE: invalid
   IMAGE: NONE
FLASHDEV: /dev/hda
Installer Main Menu:
    1. Configure Network
    2. Manufacture flash
    3. Install flash cookie
    4. Install flash image from network
    5. Install flash image from cdrom
    6. Install flash image from disk
    7. Wipe out disks and install .bin image
    8. Exit (and reboot)
Choice [0]: 3
Unknown model, cannot create cookie.
Subsequent Recovery procedures using Rescue disks from 4.1.7 and 4.2.1 detected the Model as OE512.  Option 2 creates a cookie as a MODEL OE512, which I wrote with option 3. Option 5 works, but trying to write the bin image on 4.1.7 displays this
Choice [0]: 8
Enter full URL of .bin image to install.
   ftp://[user:pass@]ip_addr/path/to/file
  http://[user:pass@]ip_addr/path/to/file
  file:/local/path/to/to/file
URL for .bin image [file:/cdrom/images/WAAS41.bin]:
Continue?  This will wipe out all disks! [n]: y
Scrogging done
Saving random seed...
dd: opening `/state/random-seed': No such file or directory
  No volume groups found
/ruby/bin/ruby_disk: First disk is missing, bad, marked bad, disabled via shutdown, or it has unknown data.
/ruby/bin/ruby_disk: Second disk is bad, missing, or shutdown; bailing out
ssmgr: open(/state/safestate, O_WRONLY|O_CREAT) failed: No such file or directory
ssmgr: op_open or media_open
ssmgr: op_create or media_init
SSMGR RETURNING: 10 (No such file or directory)
Reading and installing image, it may take a few minutes, please wait...
Error, image NOT installed.
   MODEL: OE512
  COOKIE: valid
   IMAGE: 4.1.7.11
FLASHDEV: /dev/sda
    1. Configure Network (done)
I suspect that the Installer program on the Rescue CD can't detect the Hardware properly, and thus can't find the proper drivers for the platform.
Is there any manual method of forcing the Rescue CD Installer to use a particular hardware model?
Tom
Zach Seils Tue, 07/06/2010 - 06:59
  • Cisco Employee,
Hi To,
Do you happen to have the show hardware output from when the devices are running 4.0(19)?
Zach
tgervais Wed, 07/07/2010 - 04:22
Hi Zach,
Sorry for the delay. I've found that the MODEL detection is affected by the BIOS settings of the Hard Drive Controller. If RAID is hardware enabled on the Adaptec, then 4.1. and 4.2 detects the OE612 as an OE512, and 4.0 will show the MODEL as UNKNOWN.
CHENWAE1#show disks tech-support
Disk drive not supported. (type 8 host 1 chan 0 id 128 lun 0)
Disk drive not supported. (type 8 host 1 chan 1 id 128 lun 0)
Unsupported disk hardware.
=== disk00 ===
Device: IBM-ESXS ST3146755SS      Version: BA33
Serial number: 3LN1QPDW00009805QJK8
Device type: disk
Transport protocol: SAS
Local Time is: Wed Jul  7 16:26:55 2010 IST
Device supports SMART and is Enabled
Temperature Warning Enabled
SMART Health Status: OK
=== disk01 ===
Serial number: 3LN1S1SH00009804D67D
Device type: disk
Local Time is: Wed Jul  7 16:26:56 2010 IST
CHENWAE1#show hardware
Cisco Wide Area Application Services Software (WAAS)
Copyright (c) 1999-2008 by Cisco Systems, Inc.
Cisco Wide Area Application Services Software Release 4.0.17 (build b14 Feb 27 2008)
Version: oe612-4.0.17.14
Compiled 14:42:31 Feb 27 2008 by cnbuild
System was restarted on Wed Jul  7 16:21:59 2010.
The system has been up for 5 minutes, 31 seconds.
CPU 0 is GenuineIntel Intel(R) Pentium(R) D CPU 3.00GHz (rev 6) running at 3002MHz.
CPU 1 is GenuineIntel Intel(R) Pentium(R) D CPU 3.00GHz (rev 6) running at 3002MHz.
Total 2 CPUs.
2048 Mbytes of Physical memory.
1 CD ROM drive (TSSTcorpCD-ROM TS-L162C)
2 GigabitEthernet interfaces
2 InlineGroup interfaces.
1 Console interface
Jul  7 10:57:30 CHENWAE1 kernel: %WAAS-SYS-6-900000: hda:
Jul  7 10:57:30 CHENWAE1 kernel: %WAAS-SYS-6-900000: hda1
Manufactured As: WAE-612-K9  [8849PAV]
BIOS Information:
Vendor         :IBM
Version        :IBM BIOS Version 1.06-[P6E106AUS-1.06]-
Rel. Date      :04/13/2007
  Cookie info:
    SerialNumber: KQLFKPD
    SerialNumber (raw): 75 81 76 70 75 80 68 0 0 0 0
    TestDate: 7-7-2010
    ExtModel: OE612
    ModelNum (raw): 55 0 0 0 1
    HWVersion: 1
    PartNumber: 53 54 55 56 57
    BoardRevision: 1
    ChipRev: 1
    VendID: 0
    CookieVer: 2
    Chksum: 0xfc1f
List of all disk drives:
Physical disk information:
  disk00: Present    3LN1QPDW00009805QJK8       (h01 c00 i128 l00 - Int DAS-SAS)      140011MB(136.7GB)
  disk01: Present    3LN1S1SH00009804D67D       (h01 c01 i128 l00 - Int DAS-SAS)      140011MB(136.7GB)
Mounted file systems:
MOUNT POINT      TYPE       DEVICE                SIZE     INUSE      FREE USE%
/sw              internal   /dev/md0             991MB     615MB     376MB  62%
/swstore         internal   /dev/md1             991MB     281MB     710MB  28%
/state           internal   /dev/md2            5951MB     172MB    5779MB   2%
/local/local1    SYSFS      /dev/md5            6943MB     131MB    6812MB   1%
/disk00-04       CONTENT    /dev/md4          117798MB     330MB  117468MB   0%
.../local1/spool PRINTSPOOL /dev/md6             991MB      16MB     975MB   1%
Software RAID devices:
  DEVICE NAME  TYPE     STATUS                PHYSICAL DEVICES AND STATUS
  /dev/md0     RAID-1   NORMAL OPERATION      disk00/00[GOOD]  disk01/00[GOOD]
  /dev/md1     RAID-1   NORMAL OPERATION      disk00/01[GOOD]  disk01/01[GOOD]
  /dev/md2     RAID-1   NORMAL OPERATION      disk00/02[GOOD]  disk01/02[GOOD]
  /dev/md3     RAID-1   NORMAL OPERATION      disk00/03[GOOD]  disk01/03[GOOD]
  /dev/md4     RAID-1   REBUILDING            disk00/04[GOOD]  disk01/04[!!NOT U
P TO DATE!!]
  /dev/md5     RAID-1   REBUILDING            disk00/05[GOOD]  disk01/05[!!NOT U
P TO DATE!!]
  /dev/md6     RAID-1   NORMAL OPERATION      disk00/06[GOOD]  disk01/06[GOOD]
  *** NOTE ***
  One or more RAID constituent disk partitions appear to be abnormal.
  This could be because of
  problem in drive's partition(s) and it is being rebuilt
  Possible I/O errors on a disk drive
  Please run "show alarms critical detail support"
  to check any critical disk errors.
  RAID-1 volumes will continue to operate on the remaining disk drive.
  Please refer to the product documentation for further
  information on how to handle this situation.
Disk encryption feature is disabled.
My original problem persists though; if I upgrade this platform to 4.2,  the drives are no longer detected as "good"
Welcome to the installer.  The installer will enable installation
of a new software image onto your system, or recover a previous image
in the event that the hardware was changed.
   MODEL: OE612
  COOKIE: valid
   IMAGE: 4.2.1.38
FLASHDEV: /dev/sdc
    7. Recreate RAID device (WAE-674/7341/7371 only)
    8. Wipe out disks and install .bin image
    9. Exit (Eject and reboot)
Choice [0]: 8
URL for .bin image [file:/cdrom/images/WAAS40.bin]:
Scrogging sda sdb done
scan_612_disk_map: Can't open . Errno=2
change_disknum_612 failed!
Any insight would be greatly appreciated.
Sincerely,
Tom
Zach Seils Wed, 07/14/2010 - 05:43
  • Cisco Employee,
What led you to change the Adaptec configuration?  I was able to make the disks "disappear" by enabling RAID in the Adaptec settings, but this doesn't surprise me (we don't support hardware RAID on the 1RU platforms).
What is the state of the device prior to upgrading?  Does the WAAS software boot?  If so, can you send me a tech-support from the device?
Zach
tgervais Wed, 07/14/2010 - 08:08
Hi Zach,
I was directed to do so by TAC, although I wasn't sure why, since our other WAE-612-k9s didn't have this option enabled.
After disabling the hardware raid, the WAE could run any 4.0.x version, but could not upgrade to 4.1/4.2. I tried both the "rescue CDs" for 4.1/4.2, and the "copy ftp install" methods. "Rescue CDs" would work right up to the option for "wipe disks and install .bin" image, but would report "no disks" as shown above. The "copy ftp install" from version 4.0.27 would install the 4.2.1.38 image, but upon reboot, it would fail during the boot sequence
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Frustrated, I looked at the boot logs and might have found an issue. On the "faulty" WAE-612, the boot script detects two SCSI adapters; only one shows up in BIOS POST.
The first adapter (Adaptec AIC79XX) has no drives, but is assigned the device name "scsi0"
Under the second adapter(Adaptec AIC94XX), the Hard disks are detected, and it's assigned a device name of "scsi1"
ACPI: PCI Interrupt 0000:03:03.0[A] -> GSI 17 (level, low) -> IRQ 17
scsi0 : Adaptec AIC79XX PCI-X SCSI HBA DRIVER, Rev 2.0.30
        aic7901: Ultra320 Wide Channel A, SCSI Id=7, PCI-X 67-100Mhz, 512 SCBs
Adaptec aacraid driver 1.1-5[24495]custom-IBM
Loading AIC-94xx Linux SAS/SATA Family Driver, Rev: 1.0.8-12
Probing Adaptec AIC-94xx Controller(s)...
ACPI: PCI Interrupt 0000:03:04.0[A] -> GSI 19 (level, low) -> IRQ 19
scsi1 : Adaptec AIC-9405W SAS/SATA Host Adapter
scsi 1:0:128:0: Direct-Access     IBM-ESXS ST3146755SS      BA33 PQ: 0 ANSI: 5
adp94xx:0:128:0: Tagged Queuing enabled.  Depth 32
scsi 1:1:128:0: Direct-Access     IBM-ESXS ST3146755SS      BA33 PQ: 0 ANSI: 5
adp94xx:1:128:0: Tagged Queuing enabled.  Depth 32
AIC-94xx controller(s) attached = 1.
To contrast, our functioning WAE-612s do not have this second detected Adaptec host adapter, and are properly assigned a "scsi0" for their device name.
scsi0 : Adaptec AIC-9405W SAS/SATA Host Adapter
scsi 0:0:128:0: Direct-Access     IBM-ESXS MBA3300RC        SA06 PQ: 0 ANSI: 5
scsi 0:1:128:0: Direct-Access     IBM-ESXS MBA3300RC        SA06 PQ: 0 ANSI: 5
On our faulty WAE-612,  in the section that tries to mount the detected drives, it appears that the script is looking for the physical drives under the "scsi0" device name, using the AIC94XX driver.. .
2010 Jul  8 08:58:41 (none) kernel: %WAAS-SYS-3-900000: Attached scsi disk sda a
t scsi1, channel 0, id 128, lun 0
2010 Jul  8 08:58:41 (none) kernel: %WAAS-SYS-3-900000: Attached scsi disk sdb a
t scsi1, channel 1, id 128, lun 0
2010 Jul  8 08:58:41 (none) kernel: %WAAS-SYS-3-900000: Attached scsi removable
disk sdc at scsi2, channel 0, id 0, lun 0
BOOT-100: disk apply
I'm guessing this fails because there are no physical drives on "scsi0", they are assigned on "scsi1". If the disk mapping script  would've tried , I think the drives would've been mounted properly.
I was hoping there was a modified script out there somewhere, but after our 3rd RMA'd WAE exhibited the same characteristics (these were all in Chennai India), I directed the onsite tech to remove the Adaptec 29320ALP UltrasSCSI adapter.
With the adapter removed, the 4.2.1.38 code installed and booted properly.
When I forwarded my results to TAC, our Rep mentioned that the WAE-612-k9 ships with both ACNS and WAE capabilities. He said that ACNS uses that additonal SCSI card.
I'm fairly sure our configuration is not unique; our environment consists of  32 WAEs, and this is the first time that I've encountered this issue.
I'm just happy it's resolved now.
Thanks for your insight, Zach
Tom
Zach Seils Tue, 07/20/2010 - 07:54
  • Cisco Employee,
Hi Tom,
What is the TAC case # you have been working under?
Zach
tgervais Tue, 07/20/2010 - 08:05
Hi Zach,
It was /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} 614759583.
Tom
