2 Different Application on Same Server: 2 VIP
Jul 3rd, 2010
I need one help..
1. I have 2 different Application installed on same Server (Web Portal & SSO)
2. Both these applications need to be load balanced.
3. 2 VIP is available.
Traffic Flow:
Internet User--> Web Server--> SSO Server
How ACE will do the load balancing for these 2 applications?
kindly suggest..
dario.didio Mon, 07/05/2010 - 00:22
The ACE can do this without any problem.
Define your real server:
rserver SERVER1
ip address 192.168.1.1
inservice
Define 2 serverfarms ( one serverfarm per application, define the TCP port on your rserver)
serverfarm PORTAL
rserver SERVER1 80
  inservice
serverfarm SSO
rserver SERVER1 443
  inservice
Define 2 class maps:
class-map match-any PORTAL-80
match virtual-address 172.16.1.1 tcp eq 80
class-map match-any SSO-443
match virtual-address 172.16.1.2 tcp eq 443
Define 2 policy-maps
policy-map type loadbalance first-match PORTAL
class class-default
  serverfarm PORTAL
policy-map type loadbalance first-match SSO
class class-default
  serverfarm SSO
Define a L3 policy-map:
policy-map multi-match VIPS
class PORTAL-80
  loadbalance vip inservice
  loadbalance policy PORTAL
  loadbalance vip icmp-reply active
class SSO-443
  loadbalance policy SSO
activate this on your interface
vlan 10
service-policy input VIPS
HTH,
Dario
