Giuseppe Larosa Sun, 07/04/2010 - 04:39
  • Hall of Fame,
    Founding Member
Hello Sunish,
NAT is not supported on C3560.
Only C6500 with Sup720 supports hardware assisted NAT
you likely need to deploy a sw router to perform NAT
Hope to help
Giuseppe
Ganesh Hariharan Sun, 07/04/2010 - 07:55
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
I would like to know 3560 Switch support NAT or not
Sunish
Hi Sunish,
No cisco 3560 does not support nat functionality, only 6500 and 5500 series with min ios  11.2 (P) series support in switches seires.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a008011c629.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
hobbe Sun, 07/04/2010 - 13:13
  • Gold, 750 points or more
The 3560 does NOT support NAT,
However there are/can exist NAT commands in the IOS for the 3560 switches but the commands do not work.
When you type the command it does not say it does not work it accepts it just as it should work, but it just does not do anything.
good luck
johnlloyd_13 Tue, 08/16/2011 - 17:59
  • Blue, 1500 points or more
hi sergio,
yes in PT, the 3560 does support NAT. however, in real switches it's not.
PT:
Switch#sh ver
Cisco IOS Software, C3560 Software (C3560-ADVIPSERVICESK9-M), Version 12.2(37)SE1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 05-Jul-07 22:22 by pt_team
Image text-base: 0x00003000, data-base: 0x01500000
Switch(config)#ip nat ?
  inside   Inside address translation
  outside  Outside address translation
  pool     Define pool of addresses
real 3560:
C3560#sh ver
Cisco IOS Software, C3560 Software (C3560-ADVIPSERVICESK9-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 21-Aug-08 15:26 by nachen
Image text-base: 0x00003000, data-base: 0x01A00000
C3560(config)#ip nat ?
% Unrecognized command
