6.1.4 cluster not honoring CSS (apparently).
Jul 4th, 2010
Hi, I'm managing 3  6.1.4 clusters and got similar results in CSS restricting calls. Most of the DN CSS are unrestrictive (by company policy) but a few DNs need to be blocked any type of call (even extension to extension). Usually phones have a site Device Pool assigned to them in which they should heir location and region information but they don't have a CSS applied (set to NONE). DNs, however, do have a CSS that points to all allowed partitions, usually external routes for each kind (extensions, local, mobile, long distance and international).
Some of new deployed phones (CIPC but the problem happens with all SCCP types, never tried SIP for this issue), have a regular extension partition in their DNs but the CSS applied is a restrictive one which lists only a restrictive partition (to which there is no DN, route patterns or any other applicable element).
The phone can place calls to regular extensions in that in the same partition and to other partitions as well (that are not listed inside the restrictive CSS, not even the restrictive partition is). Dialed Number Analyzer shows that the call would be blocked.
The Device Pool has Device Mobility Group CSS information allowing all type of calls. WIll DMG CSS override the phone NONE CSS? I suppose the DN CSS should take precedence over other CSS and even DMG's CSS should not interfer in that. Even setting DMG to NONE had no effect. Restricted
Could this be a bug in CUCM 6.1.4-2000 or something very odd in the setup I'm working on? My Cisco reseller/service provider was not able to provide me a straight answer that's is a bug or not. It might be coincidence but some other cluster manager from another office where calls are more restricted said we started seeing this behavior sometime in november and cluster was upgraded from 6.1.3 in october.
Overall Rating: 5 (1 ratings)
gogasca Wed, 07/07/2010 - 10:56
Do you know if those phones are in Mobility mode, otherwise DM CSS should not kick in.
To give you a better explanation please place a call and you should be abl eto see pss="" in CUCM SDI detailed traces or todpss for time of day CSS
if you upload CUCM SDI with calling, called number and timestamp I Can tell you what exactly CUCM is doing.
rodmont74 Wed, 07/07/2010 - 11:39
Thanks a lot. The phones are in their home region when tested. I'll give another test call to generate some SDI data and paste them back.
rodmont74 Tue, 07/13/2010 - 07:16
Hi, I have both Publisher and Subcriber (It's a two server cluster, phones
register at Sub as primary call control server and fail to Pub). I got the SDL between 10:00 and 10:05 AM as I did new tests.
The extension I used is 4101 at PTT-BRSAOP-JK-INT partition and this DN has a restrictive CSS limiting calls only to the same phone partition.
One call ID example is 48599868 to an external local number.
In this test, by CIPC is roaming from home location.
The DNA shows another external call should be blocked but you can see it logged in SDI output.
I can upload the whole SDI output for the cluster if this helps too.
Thanks a lot.
Related Content
