smart tunnel restriction
Jul 4th, 2010
hi all,
is there a way to limit smart tunnel per resource?
when a bookmark is used with smart tunnel the relay plugin tunnel all the requests from that browser , i would like to limit that
Jason Gervia Tue, 07/06/2010 - 06:23
You can filter access to internal resources, but if you want to not smart tunnel all the resources for that particular browser, you'd have to use 8.3(1).
--Jason
