Factory Reset
Answered Question
Jul 4th, 2010
Hi all,
Just a quick one, how do I set a Cisco SD IP Camera Indoor Dome 2420 Series back to factory default settings?
I have 4 Cisco cameras setup but for some reason I cannot access the 4th camera.
On the router, I can see arp entry but it is incomplete. All 4 camera is setup in a VLAN which has DHCP enable.
Correct Answer by David Hailey about 6 years 9 months ago
There is a reset button on the rear of the device.  You can perform various resets based on how long you hold the reset button.  Check out the info here:
http://conft.com/en/US/docs/security/physical_security/video_surveillance/ip_camera/1_0/english/user_guide/ipug.pdf
Hailey
Please rate helpful posts!
Overall Rating: 5 (1 ratings)
