Unity Connection and Busy greeting
JustForVoice_2
Level 4
Level 4
Hi all,
I have Unity connection 7 and CUCM7 in my phone I made the busy trigger 2 and I checked forward busy internal and external to voice mail.
in Unity connection I select my user then greeting and I chosed busy greeting and I add new sound file and then save. but it is not working.
I made call to my IP phone and answer then call from another IP phone the call forwarded to Unity but with default greeting not busy greeting.
why I do not know ?
I do not know if there is any application in Unity connection shows me the call and the forward reason like Unity.
any body can help me?
2 Accepted Solutions
Rob Huffman
Hey JFV,
Let's take a look at another area for a moment just to be sure
For the User in question that you are using for testing the Busy Greeting
config. Can you have a look (via) UC admin >User > Edit > Greetings and
check to see if the Checkbox for "Busy" has a checkmark to indicate it has
been enabled?
The Busy greeting can be recorded/saved without actually turning it on. So
let's see what that says as a starting point.
Cheers!
Rob
Rob Huffman
Hey JFV,
Sorry for the delay
The first chart I sent was Q.931 redirect reason codes which are not applicable for
the Remote Port Status Monitor (sorry I didn't read your early references in this thread.
For Unity Connection the Reason=2 does reflect "Call Forward Busy" so you are seeing
what is expected here.
Here are my test examples;
Busy
10:04:08, New Call, CalledId=5126,  RedirectingId=5126,  Origin=16,  Reason=2,  CallGuid=2D65595429F74F1DBEEE5E79AC2ED2CD,  CallerName=Rob Huffman,  LastRedirectingId=5126,  LastRedirectingReason=2,  PortDisplayName=CallManager-1-001,[Origin=Invalid],[Reason=Invalid]
10:04:08, AttemptForward
10:04:08, State - AttemptForward.cde!Dummy
10:04:08, Event is [NULL]
10:04:08, PHTransfer
10:04:08, State - PHTransfer.cde!LoadInfo
10:04:08, Event is [TrueEvent]
10:04:08, PHGreeting
10:04:08, State - PHGreeting.cde!PlayGreeting
10:04:08, Call answered if needed
10:04:08, Playing greeting for Subscriber:  bob uncle
10:04:20, No DTMF received
10:04:20, Playing greeting for Subscriber:  bob uncle
10:04:20, Event is [RecordMsgEvent]
10:04:20, State - PHGreeting.cde!RecordMsg
10:04:45, Event is [NULL]
10:04:45, State - PHGreeting.cde!RunEditMsg
10:04:45, -->MessageEditing
10:04:45,         State - MessageEditing.cde!CheckMsgMenuOpt
10:04:45,         Event is [EditMessageMenuEvent]
10:04:45,         State - MessageEditing.cde!PlayEditMenu
10:04:45,         Event is [HangupEvent]
10:04:45,         State - MessageEditing.cde!CheckMsgLength
10:04:45,         Event is [ManyEvent]
10:04:45,         State - MessageEditing.cde!SendMsg
10:04:45,         Event is [TrueEvent]
10:04:45,         State - MessageEditing.cde!ConfirmSend
10:04:45, <--MessageEditing
10:04:46, Idle
No Answer
10:06:54, New Call, CalledId=5126,  RedirectingId=5126,  Origin=16, Reason=4,  CallGuid=56B7A0E09EC246BE9BB56CC28CEE2769,  CallerName=Rob Huffman,  LastRedirectingId=5126,  LastRedirectingReason=4,  PortDisplayName=CallManager-1-004,[Origin=Invalid],[Reason=Invalid]
10:06:54, AttemptForward
10:06:54, State - AttemptForward.cde!Dummy
10:06:54, Event is [NULL]
10:06:54, PHTransfer
10:06:54, State - PHTransfer.cde!LoadInfo
10:06:54, Event is [TrueEvent]
10:06:54, PHGreeting
10:06:54, State - PHGreeting.cde!PlayGreeting
10:06:54, Call answered if needed
10:06:54, Playing greeting for Subscriber:  bob uncle
10:07:00, No DTMF received
10:07:00, Playing greeting for Subscriber:  bob uncle
10:07:01, Event is [RecordMsgEvent]
10:07:01, State - PHGreeting.cde!RecordMsg
10:07:16, Event is [NULL]
10:07:16, State - PHGreeting.cde!RunEditMsg
10:07:16, -->MessageEditing
10:07:16,         State - MessageEditing.cde!CheckMsgMenuOpt
10:07:16,         Event is [EditMessageMenuEvent]
10:07:16,         State - MessageEditing.cde!PlayEditMenu
10:07:16,         Event is [HangupEvent]
10:07:16,         State - MessageEditing.cde!CheckMsgLength
10:07:16,         Event is [ManyEvent]
10:07:16,         State - MessageEditing.cde!SendMsg
10:07:16,         Event is [TrueEvent]
10:07:16,         State - MessageEditing.cde!ConfirmSend
10:07:16, <--MessageEditing
10:07:16, Idle
Call Forward All
12:19:32, New Call, CalledId=5126,  RedirectingId=5126,  Origin=16,  Reason=8,  CallGuid=247106BE4A6640AE906F28D1E91EADCA,  CallerName=Rob Huffman,  LastRedirectingId=5126,  LastRedirectingReason=8,  PortDisplayName=CallManager-1-003,[Origin=Invalid],[Reason=Invalid]
12:19:32, AttemptForward
12:19:32, State - AttemptForward.cde!Dummy
12:19:32, Event is [NULL]
12:19:32, PHTransfer
12:19:32, State - PHTransfer.cde!LoadInfo
12:19:32, Event is [TrueEvent]
12:19:32, PHGreeting
12:19:32, State - PHGreeting.cde!PlayGreeting
12:19:32, Call answered if needed
12:19:32, Playing greeting for Subscriber:  bob uncle
12:19:39, No DTMF received
12:19:39, Playing greeting for Subscriber:  bob uncle
12:19:39, Event is [RecordMsgEvent]
12:19:39, State - PHGreeting.cde!RecordMsg
12:19:50, Event is [NULL]
12:19:50, State - PHGreeting.cde!RunEditMsg
12:19:50, -->MessageEditing
12:19:50,         State - MessageEditing.cde!CheckMsgMenuOpt
12:19:50,         Event is [EditMessageMenuEvent]
12:19:50,         State - MessageEditing.cde!PlayEditMenu
12:19:50,         Event is [HangupEvent]
12:19:50,         State - MessageEditing.cde!CheckMsgLength
12:19:50,         Event is [ManyEvent]
12:19:50,         State - MessageEditing.cde!SendMsg
12:19:50,         Event is [TrueEvent]
12:19:50,         State - MessageEditing.cde!ConfirmSend
12:19:50, <--MessageEditing
12:19:51, Event is [HangupEvent]
12:19:51, Idle
Cheers!
Rob
13 Replies 13
Thank you for your reply I download the tool and I collected the output but there is nothing clear. why it is not playing Busy Greeting message
New Call, CalledId=XXX,  RedirectingId=XXX,  Origin=16,  Reason=2,  CallGuid=1D6609DE51E54B7AA716CA3F9C12E3CD,  CallerName=CallingParty Name,  LastRedirectingId=XXX,  LastRedirectingReason=2,  PortDisplayName=PhoneSystem-1-001,[Origin=Invalid],[Reason=Invalid]
AttemptForward
Event is [NULL]
PHTransfer
PHGreeting
Playing greeting for Subscriber:  CalledPartyName
No DTMF received
Event is [NULL]
-->MessageEditing
         Event is [NULL]
<--MessageEditing
Event is [NULL]
State - PHGreeting.cde!AfterMsg
Event is [NULL]
Idle
Jaime Valencia
If I'm following correctly, you're never testing if CFB works or not. The config might be OK, but your testing is not, according to what you mentioned.
busy trigger 2
Let's say this is on Phone A
Phone B calls Phone A, that's 1 call
Phone C calls Phone A, that's 2 calls
So, when are you calling the 3rd time to get the CFB???
In case you don't understand why it doesn't work, read this:
Busy Trigger
This setting, which works in conjunction with Maximum Number of Calls  and Call Forward Busy, determines the maximum number of calls to be  presented at the line. If maximum number of calls is set for 50 and the  busy trigger is set to 40, incoming call 41 gets rejected with a busy  cause (and will get forwarded if Call Forward Busy is set). If this line  is shared, all the lines must be busy before incoming calls get  rejected.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thank you for your reply,
I tested the CFB before.
I un-checked the FB internal and external. and with second call I got busy tone
One more thing is thing, Is there any refernce to know the meaning of the reason, like in my case:
Reason=2
what is the meaning of 2?
Hi JFV,
Here are the code descriptions;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_0_1/cdr-defs/cdrcodes.html#wp1062874
Cheers!
Rob
Redirect Reason Codes
Table 6-4 contains the available Redirect Reason Codes that may appear in a record.
Table 6-4     Redirect Reason Codes
Q.931 Standard Redirect Reason Codes
Value
Description
Unknown
Call Forward Busy
Call Forward No Answer
Call Transfer
Call Pickup
7
Call Park
8
Call Park Pickup
9
CPE Out of Order
Call Forward
11
Call Park Reversion
15
Call Forward all
Nonstandard Redirect Reason Codes
18
Call Deflection
34
Blind Transfer
50
Call Immediate Divert
66
Call Forward Alternate Party
82
Call Forward On Failure
98
Conference
114
Barge
129
Aar
130
Refer
146
Replaces
162
Redirection (3xx)
177
SIP-forward busy greeting
207
Follow Me (SIP-forward all greeting)
209
Out of Service (SIP-forward busy greeting)
239
Time of Day (SIP-forward all greeting)
242
Do Not Disturb (SIP-forward no answer greeting)
257
Unavailable (SIP-forward busy greeting)
274
Away (SIP-forward no answer greeting)
303
Mobility HandIn
319
Mobility HandOut
335
Mobility Follow Me
354
Recording
370
Monitoring
399
Mobility IVR
415
Mobility Cell Pickup
418
Click to Conference
Thank you rob for this nice table
in my case it is 2 which is Call Forward No Answer
and it should be 1.
I checked the setting of my phone it is:
Maximum Number of Calls:2
Busy Trigger:1
and
Forward Busy Internal and external to voice-mail.
Is it Ok like this or I should change somthing to make the reason 1?
Rob Huffman
Hey JFV,
been enabled?
Cheers!
Rob
Thnak you too much
it solved my problem and by mistake I rated 4 from 5
sorry I was too happy so I pressed 4 rather than 5
Rob Huffman
Hey JFV,
Great work my friend
It's all good from my end! The ability to actually turn on the Busy Greeting
can be done by you (the Admin) via the route we just used, or via
the TUI (by the User). Try a new test user Record/save the Busy Greeting
and then edit the Busy Greeting and you should get the option to turn it on
with "no end date". I just tried this out on one of our test users.
Cheers!
Rob
Thank you too much
it is very good method,
I tested it is OK
Rob but one more thing
till now if I checked the posrt status monitoy the reason is 2 not 1 do you hvae any Idea? or I am looking for wrong line?
05:21:21, New Call, CalledId=XXX,  RedirectingId=XXX,  Origin=16,  Reason=2,  CallGuid=4E0E3C0959E846E8BB7E04585F292215,  CallerName=XXXXXXXXX,  LastRedirectingId=XXX,  LastRedirectingReason=2,  PortDisplayName=PhoneSystem-1-001,[Origin=Invalid],[Reason=Invalid]
05:21:21, AttemptForward
05:21:21, State - AttemptForward.cde!Dummy
05:21:21, Event is [NULL]
05:21:21, PHTransfer
05:21:21, State - PHTransfer.cde!LoadInfo
05:21:21, Event is [TrueEvent]
05:21:21, PHGreeting
05:21:21, State - PHGreeting.cde!PlayGreeting
05:21:21, Call answered if needed
05:21:21, Playing greeting for Subscriber: XXXXXXXXX
05:21:28, Event is [HangupEvent]
05:21:29, State - PHGreeting.cde!DoHangup
05:21:29, Event is [HangupEvent]
05:21:29, Idle
Rob Huffman
Hey JFV,
Sorry for the delay
Busy
10:04:46, Idle
No Answer
10:07:16, Idle
Call Forward All
12:19:51, Idle
Cheers!
Rob
Thank you too much rob for your help
I realy appreciate your efforts.
