Cisco WAAD Deployment with Allot Netenforcer
Jul 5th, 2010
While deploying Cisco waas in inline mode with allot,I am facing interface issues.
Set up is like  router-->cisco waas-->allot-->l2 switch.
Can you pleas hep.
Ravi
tgervais Mon, 07/05/2010 - 01:55
Hi Ravi,
I've had interface issues with inline cards whenever there's a speed difference, ie. 100m vs 1gb, etc, with the LAN/WAN endpoints. I'm not sure what type of interfaces your Netenforcer uses, but the following link may be helpful.
http://conft.com/en/US/docs/app_ntwk_services/waas/wae/module/inline/installation/guide/17880fru.html#wp39911
You may need a crossover cable somewhere inline.
Hope this helps.
robertsoto Tue, 07/19/2011 - 22:25
Hi dear,
I will apreciate that you send the LINK again , becouse when I try to opened the link not reponse.
I have a same case the Ravi.
SW --> WAAS --> ALLOT --> ROUTER.
I need information about the issue when in the implementation is the ALLOT with the WAE.
ravi.kumar6 Tue, 07/19/2011 - 22:44
Yes there is challenge in placing the WAAS device in inline mode and its is not with waas but with any wan optimization device.
Best way is to use WCCCP mode and redirect some specific traffic . If everything goes well, you can redirect the complete subnet using WCCP mode.
Ravi Kumar
Technical Specialist- ITS
GSM:+91-9810908415
