Call Recording issue on UCCX7.0
Jul 5th, 2010
Hi all,
I am using a UCCX 7.0. I am recording a file on Cisco supervisory Dekstop. Files are saving properly. But I am unable to hear the voice of recorded file. What will be the actual format to play and listen the saved record file. Also when we made a new work flow than how to add an agent in that new work flow.
Ali Raza
htluo Mon, 07/05/2010 - 07:51
How big are the files?  Are they 24 bytes or larger than 24 bytes?
What kind of monitoring are you using?  Desktop Monitoring or Server-based Monitoring?
Thanks!
Michael
waqas0612147 Mon, 07/05/2010 - 10:56
Files are larger than 24 byte and using the Dekstop monitoring
Ali Raza
