Jul 5th, 2010
  we are facing a problem when integrating UCCX with Web services, we are having the error as shown in Script_Error, we are
  trying to call a WSDL file that has one function which we should query to retreive the results. we have tried to append
  the parameters in the GET and POST method but none of them succeded.
  Can UCCX built in functions can support such dynamic procedures as calling first the WSDL file and then query the page that has results
   and should we use Get or POST methods.
  The overall script is attached.
cndilip123 Wed, 07/14/2010 - 21:13
I am not really answering your question.... but if you are really stuck...
You can use Java. Use Axis to communicate with the web-service and write a Java code perform actions on the web-service. Use this Java class in your scripts.
BTW are you able to use the URL in a browser and pass parameters.... getting back the xml?
lohjintiam Mon, 11/29/2010 - 06:26
What was the outcome of this? Was it possible using this method or you have to use Java?
