show current PPP authentication protocol chap / pap
Jul 5th, 2010
does anyone know a easy way to show the currrent PPP authentication protocol that is used ?
I just found on how to get it from the debug output.
But if there is an existing connection, how can I make the router show the protocol that is currently used or that was sucessfull used to authenticate.
Thank you all for the input.
chris
cisco.xenpak1 Tue, 07/06/2010 - 04:10
Hi Marcel,
so it looks like, there is no seperate command to see this.
Because I have sometimes to configure it for chap and pap and then if chap is working ok, I would like to turn the support for pap off.
Sometimes it is not possible to get the info from the debug, when there is an existing connection.
Otherwise I would have to interrupt the connection.
Thx for your answer.
Chris
cisco.xenpak1 Tue, 07/06/2010 - 04:13
Hi Smitesh,
thank you for your answer.
In my case, I have chap and pap configured at the same time. Then after the connection is established, I am able to check the router.
In my config I have configured both methods.
