07-05-2010 06:30 AM
Hi, is it possible to configure 2 Ironport S370 appliances as an real cluster?
Our customer want's to configure an proxy in the IE, so it ist neccessary that the two ironports share one IP address.
Solved! Go to Solution.
07-06-2010 04:27 AM
As far as I'm aware the S-series can not act as a cluster with a single IP address.
I think your options are to use either: WCCP or a Proxy Auto Config file (.pac file).
07-06-2010 04:27 AM
07-06-2010 04:50 AM
Thank you for your response.
I discussed this issue with an technician from Ironport this morning:
He gave me the same answer.
