ACE ftp inspection for a VIP giving other services.
Answered Question
Jul 5th, 2010
Hello community,
I am very new to ACE domain and would like to be adviced.
ACE module since version A2(1.x) has stricter error checks for application protocol  inspection. Generic class-map matching is no longer accepted.
(http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/release/note/racea2_x.html#wp365052)
With this being said, we were wondering in the case of a VIP giving services to other ports (not only ftp with inspection) if there was some recommendations or best practice about the corresponding configuration :
- Only one VIP configured (one 'match virtual address' with an extended port range + inspect ftp)
or
- Two VIPs : One with ' match virtual-address x.x.x.x tcp eq 21' + 'inspect ftp' / And One with a more generic port range ?
or any other approach ?
Any suggestion would be appreciated.
Thanks.
Karim
Correct Answer by UHansen1976 about 6 years 6 months ago
Hi Karim,
I'd recommend a per-service based configuration approach.
This way, you can configure service-specific features (e.g parameter maps, application inspections) for each service, even if you have several services configured for the same VIP. I find this gives much greater flexibility.
hth
/Ulrich
Overall Rating: 5 (1 ratings)
Correct Answer
UHansen1976 Mon, 07/05/2010 - 10:29
Hi Karim,
hth
/Ulrich
krahmani323 Mon, 07/05/2010 - 10:54
Hello Ulrich,
Thank you for your recommendations. I appreciate.
Regards.
Karim
