Terminal server-connecting to console port on a switch
Jul 5th, 2010
I am trying to connect a Cisco 2620 with an NM-16A= card to a Cisco switch console port so that I can telnet via this router to the switch. The switch is to be used as a standalone ethernet aggregate solution so I cannot just use one of the 10/100 ethernet ports on the switch itself.
Only problem is I cannot get the switch console port to bring up the port on the NM-16A= card. The NM-16A port will come up to either the console or Aux port on a router however when I connect the NM-16A= port to the console port on the switch it will not activate.
Also could somebody provide me a link to the required commands to configure this NM-16A= card correctly?
Joe Clarke Mon, 07/05/2010 - 12:40
Under the async line on your terminal server, all you require is:
line X
no exec
speed 9600
stop 1
This assumes your switch's console baud is set to the default of 9600 bps.  Depending on the switch model, you may also try connecting a rolled vs. straight-through cable to see if that makes a difference.  On a PC-to-console connection for a Cat3k, for example, you would use a rolled cable.
j-gavigan Tue, 07/13/2010 - 07:12
Hi Joseph, thank you fpr your reply. I posted this and then promptly went on holidays hence my slow reply!
I tried to implement your config however it fails to work. The first available line on my NM16=A card appears to be line 33. I configure as per your guidance to no avail as the port refuse's to come up to the console port on my switches (I've tried a couple of switches by now). I've also tried your rollover cable suggestion and that does not work either, My router is a 2620 and the switch is a WS-C3560-24TS. I also configured the switch console port as 9600, stopbits 1. I think that 9600 may be the default rate for this port anyhow so it probably made no real difference...
Joe Clarke Tue, 07/13/2010 - 21:10
Are you using an octal cable out of the 2620?  If so, try a straight-through ethernet cable.  Yes, 9600 baud is correct.
