LDAP Integration issue- MeetingPlace Express 2.1.1.2
Shaijala
Hello ,
I have sucessfully installed Cisco Unified MeetingPlace Express 2.1.1.2
i can able to make audio/web conf .but i am unable to integrate with LDAP
while i am testing LDAP configuration i am getting below error
" Error while testing AXL configuration. Cisco Unified Communications Manager
is not available "
attached LDAP conguration and error
It would be great if any one can help me on this .
Thanks ,
Sam
Shaijala
CUCM IP -172.22.16.10
AXL User-CUMPAXL
AXL URL-https://172.22.16.10:8443/axl
Jaime Valencia
I'd recommend you to re-create the whole config following this doc
Cisco Unified MeetingPlace Express, Release 2.x  -- How to Configure User Authentication By an External Directory
http://docwiki.cisco.com/wiki/Cisco_Unified_MeetingPlace_Express%2C_Release_2.x_--_How_to_Configure_User_Authentication_By_an_External_Directory
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks Java ,
The same document i followed for LDAP confguration .
previously it was working for few time .
RTMT logs i can able to see MPX contacting to CUCM .
Attacehd the RTMT AXL /MPX logs
Thanks ,
Sam
Please can any one give replay  on this .still i am not able to complete the LDAP integration .
Thanks ,
Shaijal
