Nac Upgrade
Answered Question
Jul 5th, 2010
Could you tell me the best way to upgrade cisco nac software from 4.1.3 to 4.7.2. What main issues i am likely to face when i do the upgrade?
Prasanth Mathews
Correct Answer by Faisal Sehbai about 6 years 7 months ago
Prasanth,
You're right. 4.7.1 upgrade is through ISO and the .tar.gz option isn't available. For 4.7.2, if you use the ISO then you reimage it. To upgrade to 4.7.2, you have to use the .tar.gz.
HTH,
Faisal
Prasanth,
Yes to number 1.
For going to 4.7.2 you'll have to use the .tar.gz file, NOT the ISO. If you use the ISO, you'll re-image your device. Also you have to run the .tar.gz upgrade script from the console and not in a SSH session!
HTH,
Faisal
Prasanth,
You'll have to go to 4.5.x or 4.6.x, and then jump from there to 4.7.2. Make sure you take backups along the way.
Full details here: http://tinyurl.com/2bymy9q
HTH,
Faisal
Overall Rating: 5 (3 ratings)
Prasanth Mathews Wed, 07/07/2010 - 06:59
Thanks a lot for the reply.
Isn't it possible just to insert the 4.7.2 ISO cd and do an upgrade?
Prasanth Mathews
Faisal Sehbai Wed, 07/07/2010 - 07:35
Prasanth,
Unfortunately no. If you insert a CD, you'll end up re-imaging it. Use the .tar.gz file from Cisco's site and be at 4.5 or 4.6 already before you go to 4.7.2
HTH,
Faisal
Prasanth Mathews Wed, 07/07/2010 - 07:40
Just want to confirm
1) Use cca_upgrade-4.6.1-NO-WEB.tar.gz first to convert from 4.1.3 to 4.6.1
2) Use the iso or cca_upgrade-4.7.2-from-4.5.x-4.6.x.tar.gz
Am I right?
Can I use cca_upgrade-4.7.2-from-4.5.x-4.6.x.tar.gz on the webpage to do the upgrade whn i upgraded the software to 4.6.1?
Prasanth Mathews
Correct Answer
Faisal Sehbai Wed, 07/07/2010 - 09:05
Prasanth,
Yes to number 1.
HTH,
Faisal
Prasanth Mathews Wed, 07/07/2010 - 23:43
Hi ,
Thanks again for making things clear to me.
Once I had upgrade the version 4.6.1 to 4.7.1 using iso cd. Using the option " upgrade over serial console"
Is 4.7.2 having different approach than 4.7.1??
Thanks Again
Prasanth Mathews
Correct Answer
Faisal Sehbai Fri, 07/09/2010 - 05:45
Prasanth,
HTH,
Faisal
