Reset to factory default doesn't work on 1142 AP
Endorsed Question
Jul 6th, 2010
Dear All,
We have an AIR-LAP1142N-E-K9  deployed in a H-REAP setup.
This AP already got the configuration from the WLC when it was deployed at a remote site.
Now we moved it to another site, but it doesn't appear in the WCS and i don't see any CAPWAP debug messages on the WLC.
The routing work fine between the AP and the WLC, the AP also gets an IP address from DHCP and also received Option 43 information.
Now my guess was that the AP doesn't associate with the WLC because it has the old config file and it runs in local mode(without trying to connect to the WLC).
We want to reset to factory defaults because we want to delete the configuration and force the AP to get a new config from the WCS.
I don't know the enable password so i had to use other methods for reseting to factory defaults.
I tried to use the information from here:
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_21a_JA1/configuration/guide/scg12421aJA1-chap22-trouble.html#wp1058433
I used the "MODE button":
I get the following message from the console:
"button pressed for 5 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
But after the reboot the config is not reset, because the AP still has the same hostname and i also get error messages when the AP reads the configuration:
ip ssh version 2
% Invalid input detected at '^' marker.
transport input ssh
aaa new-model
Next thing i tried was to use the CLI and to delete the config files from the boot loader mode.
But in this case, after reaching the "ap:" prompt and entering the "dir flash:" command, i don't see the file name "config.text".
This file should hold the config and it should be renamed, but how can i rename it if it's not there ?
Can someone tell me a working procedure on how to reset the AP to factory defaults?
You can see attached a log from Putty, after i used the MODE button to delete the config.
Thanks in advance,
Adrian
Cisco Endorsed by vkg
rsreeves1 about 6 years 8 months ago
Did you ever get an answer for this?  Regardless, I believe what you're looking for is
ap: delete flash:private-multiple-fs
Are you sure you want to delete "flash:private-multiple-fs" (y/n)?y
File "flash:private-multiple-fs" deleted
That is the actual private config file.  Without it, the AP should boot up with factory defaults.
-Rob
Overall Rating: 4.9 (9 ratings)
Surendra BG Tue, 07/06/2010 - 00:23
  • Cisco Employee,
I request you to hold the mode button for 10 seconds and at the time the device comes up, issue the command  clear lwapp private-config
if you want to prime this AP to a controller then..
AP#lwapp/capwap ap ip address
AP#lwapp/capwap ap ip default-gateway
AP#lwapp/capwap ap controller ip address
Surendra
Adrian Mihailov Tue, 07/06/2010 - 00:58
I would try that, problem is that i don't have the enable password on the AP.
Do i get into the enable mode directly if i keep the button pressed for 10 seconds?
Surendra BG Tue, 07/06/2010 - 01:30
  • Cisco Employee,
No issues... nothing will hapen if we keep on holding the mode button for 10 seconds.. and make sure not more than that.. it may go toi rommon.
>> We need to issue the command "clear capwap privat-config" then the telnet, enable password will be Cisco... username will be cisco.
Adrian Mihailov Tue, 07/06/2010 - 02:39
Is there any way to clear the Lwapp config from ROMMON?
I tried yesterday to use the "Cisco" as the enable password, but it didn't work.
I will try also today, and i will capture the complete logs from Putty.
Adrian Mihailov Wed, 07/07/2010 - 03:54
I tried that reset procedure, with the MODE button pressed for 10 seconds, but it doesn't work.
The enable password is not reset, i tried "Cisco" but it doesn't work.
I receive the following message after releasing the button:
button pressed for 9 seconds
Then after the AP boots, i try to enter into enable mode, but the "Cisco" password doesn't work.
Password:
Password:
% Bad secrets
How can this AP be reset to factory defaults from ROMMON?
I can reach the "ap: " prompt, but what do i need to do there?
Surendra BG Wed, 07/07/2010 - 04:16
  • Cisco Employee,
try reboting the AP again and lets see if we could get the AP out from the AP: mode (Rommon mode).
If we are not able to then we need t ofollow the below steps..
Using the CLI
Follow the steps below to reload the access point image using the CLI. When the access point begins to boot, you interrupt the boot process and use boot loader commands to load an image from a TFTP server to replace the image in the access point.
Note Your access point configuration is not changed when using the CLI to reload the image file.
Step 1 Open the CLI using a Telnet session or a connection to the access point console port.
Step 2 Reboot the access point by removing power and reapplying power.
Step 3 Let the access point boot until it begins to inflate the image. When you see these lines on the CLI, press Esc:
Loading "flash:/c1100-k9w8-mx.v122_13_ja.20031010/c350-k9w7-mx.v122_13_ja.20031010"
Step 4 When the ap: command prompt appears, enter the set command to assign an IP address, subnet mask, and default gateway to the access point.
Note You must use upper-case characters when you enter the IP-ADDR, NETMASK, and DEFAULT_ROUTER options with the set command.
Your entries might look like this example:
ap: set IP_ADDR 192.168.133.160
ap: set NETMASK 255.255.255.0
ap: set DEFAULT_ROUTER 192.168.133.1
Step 5 Enter the tftp_init command to prepare the access point for TFTP.
ap: tftp_init
Step 6 Enter the tar command to load and inflate the new image from your TFTP server. The command must include this information:
•the -xtract option, which inflates the image when it is loaded
•the IP address of your TFTP server
•the directory on the TFTP server that contains the image
•the name of the image
•the destination for the image (the access point Flash)
Your entry might look like this example:
ap: tar -xtract tftp://192.168.130.222/images/c1100-k9w8-tar.122-13.JA1 flash:
Step 7 When the display becomes full the CLI pauses and displays --MORE--. Press the spacebar to continue.
extracting info (229 bytes)
If you do not press the spacebar to continue, the process eventually times out and the access point stops inflating the image.
Step 8 Enter the set BOOT command to designate the new image as the image that the access point uses when it reboots. The access point creates a directory for the image that has the same name as the image, and you must include the directory in the command. Your entry might look like this example:
ap: set BOOT flash:/c1100-k9w7-mx.122-13.JA1/c350-k9w7-mx.122-13.JA1
Step 9 Enter the set command to check your bootloader entries.
ap: set
BOOT=flash:/c1100-k9w8-mx.122-13.JA1/c350-k9w7-mx.122-13.JA1
DEFAULT_ROUTER=192.168.133.1
IP_ADDR=192.168.133.160
NETMASK=255.255.255.0
Step 10 Enter the boot command to reboot the access point. When the access point reboots, it loads the new image.
ap: boot
>> the default password is Cisco or cisco
Adrian Mihailov Wed, 07/07/2010 - 07:11
I can get out of the ROMMON mode, that's not the problem.
Problem is that the config file is not reset to factory defaults.
After the reboot you can see that it uses the old config file.
It has the hostname "BEDESAP8" which was the old hostname.
Also the enable password isn't changed to Cisco.
BEDESAP8>sh capwap client config
configMagicMark         0xF1E2D3C4
chkSumV2                17413
chkSumV1                40163
swVer                   3.0.51.0
adminState              ADMIN_ENABLED(1)
name                    BEDESAP8
location                BE - Dessel
Where is the config file stored?
After i issue the dir flash: i don't see the "config.text" that i should rename.
I tried renaming the lwapp_reap.cfg file, but it still has the old config.
ap: dir flash:
Directory of flash:/
2    -rwx  8455                     event.log
4    -rwx  23940                    lwapp_reap.old
5    drwx  128                      c1140-rcvk9w8-mx
8    drwx  192                      c1140-k9w8-mx.124-18a.JA2
12   -rwx  6168                     private-multiple-fs
13   -rwx  170                      env_vars
John Cook Wed, 07/07/2010 - 07:16
  • Bronze, 100 points or more
I would delete the firmware (c1140-k9w8-mx.124-18a.JA2) making sure to leave the recovery image (c1140-rcvk9w8-mx).  After a reboot, the AP should boot to the recovery image and try to join a controller using whatever discovery method you have in place.
-John
Adrian Mihailov Mon, 07/12/2010 - 04:18
After the reset to factory defaults, the AP boots with the /c1140-rcvk9w8-mx image, as you can see below.
Problem is, the configuration isn't deleted.
Loading "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx"...#############################################################################################################################################################################################################################
File "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx" uncompressed and installed, entry point: 0x4000
Someone from Cisco, can you tell me where the config file is, and how can i delete it if i don't have the "enable" password?
Thanks in advance,
Adrian
rsreeves1 Tue, 07/20/2010 - 07:23
-Rob
Adrian Mihailov Tue, 07/20/2010 - 23:31
No, i haven't received a response that works for my case.
I had to send the AP back to the site from where it got his configs and reset it from the WCS.
I'll note your solution and i'll test it the next time i encounter an issue like this one.
Adrian
lcaruso Fri, 12/10/2010 - 16:32
I tried this command, delete flash:private-multiple-fs, but it didn't work me. Any idea why?
Here's the flash contents after running the command and reloading
    2  -rwx           5  Feb 28 2002 22:49:36 -06:00  private-config
    4  -rwx         289  Feb 28 2002 18:00:11 -06:00  env_vars
    6  -rwx        2043  Feb 28 2002 22:49:36 -06:00  config.txt
    7  drwx         256  Feb 28 2002 18:18:05 -06:00  c1140-k9w7-mx.124-21a.JA1
I don't want to delete anything else without knowing if I'm deleteing the correct file.
There has got to be a way to delete the startup config.
lcaruso Fri, 12/10/2010 - 16:42
so I took a shot at it and deleted private-config and that didn't do it, so then I deleted config.txt and finally back to defaults.
Leo Laohoo Fri, 12/10/2010 - 16:37
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Just found an autonomous IOS 1240 with a valid config and I rebooted the AP to run the  "rcv" file.  Because it previously had a statically-assigned IP address, the IP address remained and I couldn't log in because I did not clear the config before the "rcv" boot.
What I did to fix this is to load the autonomous IOS using the "mode button", cleared the config and copied the "rcv" file back.
aotholland Wed, 10/10/2012 - 08:24
Hi all,
I have also the same problem,
private-multiple-fs file is deleted on flash. But it's be genereated automaticaly when AP is startup.
I have all tryed that have been described above. Help plz. Ik have to do to default factory
APc471.fe6d.c6dc#sh flash:
     2  -rwx          76   Mar 1 2002 00:04:19 +00:00  private-multiple-fs
    3  -rwx       95973   Mar 1 2002 00:20:49 +00:00  event.log
    4  -rwx           0   Mar 1 2002 00:04:19 +00:00  env_vars
   34  drwx         384  May 13 2011 14:22:20 +00:00  c1140-k9w8-mx.124-23c.JA
    7  drwx         128   Mar 1 2002 00:12:13 +00:00  c1140-rcvk9w8-mx
32385024 bytes total (25297408 bytes free)
RELOAD
using  eeprom values
WRDTR,CLKTR: 0x86000800 0x40000000
RQDC ,RFDC : 0x80000037 0x0000020b
ddr init done
IOS Bootloader - Starting system.
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x86000800, 0x40000000
RQDC, RFDC : 0x80000037, 0x0000020b
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is up.
PCIE1: VC0 is active
PCIEx: initialization done
flashfs[0]: 28 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 7093760
flashfs[0]: Bytes available: 25291264
flashfs[0]: flashfs fsck took 18 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: c4:71:fe:6d:c6:dc
Waiting for PHY auto negotiation to complete TIMEOUT !
done
Ethernet speed is 10 Mb - HALF duplex
The system has encountered an error initializing
the Ethernet port.
The system is ignoring the error and continuing to boot.
If you abort the system boot process, the following
commands will re-initialize Ethernet, TFTP, and finish
loading the operating system software:
    ether_init
    tftp_init
    boot
Loading "flash:/c1140-k9w8-mx.124-23c.JA/c1140-k9w8-mx.124-23c.JA"...###########        ################################################################################        ################################################################################        ############
File "flash:/c1140-k9w8-mx.124-23c.JA/c1140-k9w8-mx.124-23c.JA" uncompressed and        installed, entry point: 0x4000
executing...
enet halted
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Version 12.4(23c)JA, RELEASE        SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 01-Jun-10 12:29 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
FLASH CHIP:  Numonyx P33
Checking for Over Erased blocks
flashfs[1]: 28 files, 8 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32126976
flashfs[1]: Bytes used: 7093760
flashfs[1]: Bytes available: 25033216
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete.
flashfs[2]: 0 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 11999232
flashfs[2]: Bytes used: 1024
flashfs[2]: Bytes available: 11998208
flashfs[2]: flashfs fsck took 1 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
Waiting for PHY auto negotiation to complete... TIMEOUT !
Ethernet link is down.
Radio0  present 8363 8000 90020000 0 90030000 B
Radio1  present 8363 8000 98020000 0 98030000 0
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-LAP1142N-E-K9    (PowerPC405ex) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FCZ1447W2EA
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from power-on
LWAPP image version 7.0.98.0
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address:
Part Number                          :
PCA Assembly Number                  : 800-30554-06
PCA Revision Number                  : A0
PCB Serial Number                    :
Top Assembly Part Number             : 800-31273-04
Top Assembly Serial Number           :
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1142N-E-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:07.947: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:07.958: *** CRASH_LOG = YES
Security Core found.
Base Ethernet MAC address: C4:71:FE:6D:C6:DC
*Mar  1 00:00:49.990: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:49.991: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:50.557: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:50.610: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages)
*Mar  1 00:00:50.630:  status of voice_diag_test from WLC is false
*Mar  1 00:00:52.790: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:52.790: %SNMP-5-COLDSTART: SNMP agent on host APc471.fe6d.c6dc is undergoing a cold start
*Mar  1 00:00:52.839: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:00:52.898: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:52.898: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:52.898: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power source
*Mar  1 00:00:52.950: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:53.443: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio1, Timed out waiting for fw to clear txp_pndg flag
*Mar  1 00:00:53.648: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:53.752: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar  1 00:00:53.776: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:53.908: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:00:53.908: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:01:11.695:  status of voice_diag_test from WLC is false
*Mar  1 00:01:11.733: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:01:11.767: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:01:11.788: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:01:11.788: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:01:11.796: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*Mar  1 00:01:11.803: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:01:21.768: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
Yahya Jaber Wed, 10/10/2012 - 09:33
simple, delete everything on the Flash...start with new image..and you have DHCP 43, it should join automatically.
aotholland Wed, 10/10/2012 - 12:35
Hi Yahya,
Thanks for your answerd. That is my problem. Beacuse i cant download image.
I must first backup current image to tftp server.
but configure terminal not working.
If i am delete image, than i have bigger problem.
Yahya Jaber Wed, 10/10/2012 - 22:16
I would consider opening a TAC case, it will be solved in 10 minutes.
wijbrendevries Tue, 01/22/2013 - 17:03
You can reset your Aironet 1142N to factory default by 2 methods
The first method is to remove the power (adapter or the ethernet adapter when the device get its power by PoE)
Press the mode button and reconnect the power. Hold the mode button for at least 2 seconds when its powering on.
The second method is by the CLI (Telnet or Console port) in enable mode execute the following commands
write erase
reload (and confirm)
Leo Laohoo Tue, 01/22/2013 - 17:10
  • Hall of Fame,
    2017 LAN, Wireless
write erase
If you use only "write erase", the static IP address remains.
If you want to delete everything, including IP address, you have to use the command "write default-config".
Eric Kemsley Mon, 04/22/2013 - 12:50
Hold the reset button down with the AP powered on. Then unplug the power form the Ap while continuing to hold the button down. Then plug the power back in, still holding the reset button. The lights will flash on the AP. When it is blue, release the rest button. Hope that helps.
