LMS 2.6 User Tracking - Application error: URN_NOT_FOUND
Answered Question
Jul 6th, 2010
When I run a quick report in Campus Manager (User Tracking  > Reports) I get the following error appearing in a window:
Application error: URN_NOT_FOUND :  urn "ogs_server_urn" : Not found !!.
Could anybody help me?
I attach the ctm_config.txt file
thanks
Correct Answer by Joe Clarke about 6 years 6 months ago
Just as I thought.  Your SSL certificate has expired.  Go to Common Services > Server > Security >Certificate Setup, and regenerate a new certificate for this server.  Then restart Daemon Manager, and you should be set.
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 07/06/2010 - 18:30
From which directory did you get this ctm_config.txt?  I need to see the ones under NMSROOT/MDC/tomcat/webapps/campus/WEB-INF/lib and NMSROOT/MDC/tomcat/webapps/cmapps/WEB-INF/lib.
Since this is LMS 2.6, I also need to see the output of the pdshow command.
Joe Clarke Tue, 07/20/2010 - 10:30
DCRServer is not running.  Post the DCRServer.log, dcr.log, and NMSROOT/MDC/tomcat/logs/stdout.log.
Correct Answer
Joe Clarke Thu, 07/22/2010 - 22:25
