CME/CUE across WAN link deployment
Jul 6th, 2010
If I have CME 7.x and CUE 7.x co-located at one place (ex. Head Office).
From branch office which is across the WAN link, shall I register phones to head office CME across the wan link? Also shall I use all CUE features?
Is SCCP across WAN is fully supported on CME 7.x like CUCM server? Is there any limitation?
Pls. comment.
Jonathan Schulenberg Tue, 07/06/2010 - 04:19
  • Cisco Designated VIP,
    2017 IP Telephony
features? Is SCCP across WAN is fully supported on CME 7.x like CUCM server?
There is no technical limitation that makes SCCP in CME different than in UCM. The phones/CME speak the same language and as such the same requirements apply: the WAN must prioritize the voice and signaling traffic.
CME is not intended for multi-site deployments. It has no concept of locations to solve issues such as emergency calling (e.g. 911). Some small customers use remote VPN-connected phones with CME but I would not recommend multiple offices run off a single CME install.
rajesh.kumar Tue, 07/06/2010 - 04:51
Hello Jonathan
Agree CME call routing is not as sophisticated as CUCM, but technically is it possible with one CME at HO and branch phones will register with HO CME across the WAN.?
