cisco 3.3.1 SP1 problem with FWSM 4.0(8)
Jul 6th, 2010
i have FWSM added in CSM , after i discovered all the configuration on the fwsm , i tried to add an interface , the  when deploying the change , the session hanged , i accessed the fwsm to see what is the problem , i found 6 vlan interfaces deleted by the CSM , and the routes also deleted by CSM
Panos Kampanakis Mon, 07/12/2010 - 10:26
I would suggest doing a Preview Config before deploying to see what CSM is going to push.
Try to check why CSM is trying to delete clan 6? Does he see if an out of band change?
I hope it helps.
