CP-7962G & CP-7915
Jul 6th, 2010
I have a problem with CP-7962G and CP-7915 expansion module; expansion module CP-7915 does not work!
I have Cisco Unified CM version 6.1.1.2112-1 so, I must have 1.0(4) - SCCP firmware version like the following table, but
CP-7915 does not work:
My CP-7962G phone have SCCP42.8-4-1S firmware
Have you got any idea?
Thank you,
Rob Huffman Tue, 07/06/2010 - 07:01
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Paolo,
Can you please let us know if the 7915 is listed on the Device Defaults
page from CUCM Admin?
I don't think 6.1.1.2112-1 is 6.1(1b) as shown as the required
CUCM version from the first doc you linked.
6.1(1b) is shown as 6.1.1.3000-2
Upgrading from Cisco Unified Communications Manager
Release 6.0(1a) or 6.1(1a) to Release 6.1(1b) Using the UCSInstall
File
• UCSInstall_UCOS_6.1.1.3000-2.sgn.iso_part1of2
– MD5 value specifies 1e47a96d3b89b8e1dfcefef3e8cdaa3a
• UCSInstall_UCOS_6.1.1.3000-2.sgn.iso_part2of2
– MD5 value specified 885c93ae61d75978646ced37d25a791a)
http://developer.cisco.com/c/document_library/get_file?folderId=32263&name=DLFE-11841.pdf
Cheers!
Rob
Paolo Bratti Tue, 07/06/2010 - 09:24
Yes!
Have a look:
System version: 6.1.1.2112-1 is supported in 6.1(1): I think
Rob Huffman Tue, 07/06/2010 - 11:36
  • Hall of Fame,
    Founding Member
Hi Paolo,
Good stuff my friend
Maybe we are seeing this bug in action (yours show Protocllo Non Specificato);
CSCsl92973 Bug Details
7915/16 Load info in Device Defaults don't work
Symptom:
7915/16 KEM modules are listed as Protocol "UNSPECIFIED", where as TFTP config does not report loadinformation for these Modules.
Conditions:
Workaround: None
Further Problem Description:
Status
Fixed
Severity
3 - moderate
Last Modified
In Last 3 Days
Product
Cisco Unified Communications Manager (CallManager)
Technology
1st Found-In
6.1(0.9901.334)
Fixed-In
7.0(0.39000.13)
6.1(1.9901.38)
6.1(2.1000.13)
5.1(3.4105.1)
6.0(1.3107.1)
7.0(0.66666.1)
7.0(0.66666.2)
6.1(1.3116.1)
7.0(1.11000.2)
4.3(2.137)
4.3(2.138)
4.2(3)ES73
4.3(8.1)
4.3(2)ES10
6.1(3.9999.1)
Hope this helps!
Rob
Paolo Bratti Tue, 07/06/2010 - 23:50
do you think that problem is only a view problem in CM page or a firmware problem?
Paolo Bratti Wed, 07/07/2010 - 09:10
Cisco TAC engineer resolved my issue!
He compile Phone Load Name and Module 1 Load Name, like this:
Rob Huffman Wed, 07/07/2010 - 06:18
  • Hall of Fame,
    Founding Member
Hi Paolo,
This is listed as a Severity Level 3 - Bug, so it's not strictly a "Cosmetic"
issue. If I were you I would try upgrading CUCM to at least the latest 6.1(2)
version or open a TAC Case to see if there is some other way to mitigate
this problem.
Cheers!
Rob
