open translated IP from the inside
Jul 6th, 2010
we have a ASA5500 with 3 interfaces : outside, dmz, inside
we have a number of static nats translating a given public IP to a dmz servers and that all works fine.  However for testing purposes, we need to be able to access the public IP from the inside interface.
I tried the following but that did not work:
static (inside,inside) <public_IP> <dmz_IP> netmask 255.255.255.255
what translation is missing to allow users from the inside to access the public ip address?
Marcin Latosiewicz Tue, 07/06/2010 - 06:53
I would start with
static (dmz,inside) netmask  255.255.255.255
enable logging on informational level from and test.
After test do "show logg | i IP.address"
Marcin
Nagaraja Thanthry Tue, 07/06/2010 - 07:09
As Marcin said, you need to configure the static with "static (DMZ,inside) " format. Also, ensure that there is NAT translation between the inside and the DMZ. It could be identity NAT or dynamic PAT.
static (inside,DMZ) netmask
or
access-list nonat permit ip
nat (inside) 0 access-list nonat
or
global (dmz) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
This will ensure that all traffic from inside (higher security) is going to DMZ with proper NAT translations.
Hope this helps.
ronshuster Tue, 07/06/2010 - 07:32
So which one is it?
Marcin says:
Nagaraja says:
and what is the logic behind this?
Marcin Latosiewicz Tue, 07/06/2010 - 07:34
We're not contadicting each other. :-)
You need to make sure that servers from DMZ to inside are translated (what I was going for).
But at the same time, it's  best to NAT inside users to somethin on DMZ. Be it identity or PAT.
Nagaraja Thanthry Tue, 07/06/2010 - 08:11
You need both of them for proper communication between the interfaces i.e. inside and DMZ. As Marcin said, one will ensure that when your inside hosts try to access the public IP of the DMZ server, it gets translated to corresponding DMZ IP. Other one is needed to satisfy the firewall requirement i.e. NAT rules are needed when you go from higher security interface (inside) to a lower security interface (DMZ).
Hope this helps.
ronshuster Tue, 07/06/2010 - 08:43
I have added the following 2 lines to the firewall:
static (dmz,inside) 192.168.1.15 netmask  255.255.255.255
The users on the inside are 172.0.0.0\8
static (inside,dmz) 172.0.0.0 172.0.0.0 netmask 255.0.0.0
This is the translation from the outside...it was there before
static (dmz,outside) 192.168.1.15 netmask 255.255.255.255
I am still unable to access the public address from the inside or from the dmz
Nagaraja Thanthry Tue, 07/06/2010 - 08:49
Do you have any nonat or identity NAT configurations from DMZ to inside? It would look like:
nat (DMZ) 0 access-list
or
static (DMZ,inside) 192.168.1.x 192.168.1.x netmask 255.255.255.255
If you have these, that could be the reason you are not able to access. Please modify the configuration so that there is no identity nat from DMZ to inside.
Hope this helps.
