Strange Quick VPN Client Issues
Jul 6th, 2010
Here is the issue: I have a client using 2Wire DSL 2701HG-B as their Internet connection.  It has a Cisco WRV200 behind it.
The 2Wire forwards port 60443 to the Cisco for the Quick VPN software.
Here is the weirdness, I set it all up and tested it with my Verizon wireless card.  With the client certificate, the connection worked perfectly.
The VPN Will Not Work for ANY client, unless I connect up with my Verizon card first.  Then the clients can connect to the VPN, no problem.
If I don’t start the day out by connecting to that clients VPN with my Verizon card, none of their remote office can connect to the VPN.  If I connect in with my Verizon, a minute or so later, all the other clients can connect no problem.
I’m baffled.  Why would the VPN only start working unless I establish a VPN with my Verizon?
Info: I am using the latest firmware in Both Devices and the latest QuickVPN client software.
