Cisco 7206VXR & PA-GE
j2sw
I am looking to install a PA-GE interface in a 7206VXR.  I do not have a processing engine that will support Gigabit speeds.  However, I only need 200 meg out of this setup.  Is it possible to install a PA-GE and link up at Gig speeds but only get around 200 megs of throughput out of it?  I need to do this as a stop bap until a new chassis is ordered.  Possible?
vmiller
Level 7
Level 7
I doubt it. I have not tried this myself but I can see the processor complaining loudly about exceeding the bandwidth points.
Edison Ortiz
What other modules do you have on this router?
If you have few modules, you should be able to install the PA-GE.
Please refer to the datasheet for hardware and software requirements
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_data_sheet09186a0080091ce7.html
Edison
Hi Edison,
I have not dealt much in the hardware part ,so please excuse me if I am being naive.
We have a Cisco7206VXR and I want to connect two Gigabit ethernet optical links to it .
For first one , I want to free one of the existing port  Gig0/3 which is having media type RJ45 and convert it to 1 Gig Optical port.
It is showing it is in GBIC Port Container 0/3 ,So will adding an SFP-SX  do my work or I would have to plan something else?
For the second port , should I get a PA-GE card and a 1000BASE-SX SFP or a PA-GE card with GBIC-SX .
Inventory details of the router is as below.
hostname#sh inventory raw
NAME: "Chassis", DESCR: "Cisco 7206VXR, 6-slot chassis"
PID: CISCO7206VXR      , VID:    , SN: 23665845
NAME: "I/O and CPU Slot 0", DESCR: "I/O and Processor Slot Container"
PID:                   , VID:    , SN:
NAME: "NPE-G1 0", DESCR: "Cisco 7200 Series Network Processing Engine NPE-G1"
PID: NPE-G1            , VID:    , SN: 30987439
NAME: "GBIC Port Container 0/1", DESCR: "GBIC Port Container"
PID:                   , VID:    , SN:
NAME: "GigabitEthernet0/1", DESCR: "BCM1250 Internal MAC"
PID:                   , VID:    , SN:
NAME: "GBIC Port Container 0/2", DESCR: "GBIC Port Container"
PID:                   , VID:    , SN:
NAME: "GigabitEthernet0/2", DESCR: "BCM1250 Internal MAC"
PID:                   , VID:    , SN:
NAME: "GBIC Port Container 0/3", DESCR: "GBIC Port Container"
PID:                   , VID:    , SN:
NAME: "GigabitEthernet0/3", DESCR: "BCM1250 Internal MAC"
PID:                   , VID:    , SN:
NAME: "Flash Card Slot Container CPU", DESCR: "Flash Card Slot Container CPU"
PID:                   , VID:    , SN:
NAME: "disk2", DESCR: "128MB Compact Flash Disk for NPE-G1"
PID: MEM-NPE-G1-FLD128 , VID:    , SN:
NAME: "NPE Inlet Temperature 0", DESCR: "NPE Inlet Temperature Sensor"
PID:                   , VID:    , SN:
NAME: "NPE Outlet Temperature 0", DESCR: "NPE Outlet Temperature Sensor"
PID:                   , VID:    , SN:
NAME: "+3.45 V Voltage 0", DESCR: "+3.45 V  Voltage Sensor"
PID:                   , VID:    , SN:
NAME: "+5.15 V Voltage 0", DESCR: "+5.15 V  Voltage Sensor"
PID:                   , VID:    , SN:
NAME: "+12.15 V Voltage 0", DESCR: "+12.15 V  Voltage Sensor"
PID:                   , VID:    , SN:
NAME: "-11.95 V Voltage 0", DESCR: "-11.95 V  Voltage Sensor"
PID:                   , VID:    , SN:
NAME: "Gi0/1", DESCR: "BCM1250 Internal MAC RJ45"
PID:                   , VID:    , SN:
NAME: "Gi0/2", DESCR: "BCM1250 Internal MAC RJ45"
PID:                   , VID:    , SN:
NAME: "Gi0/3", DESCR: "BCM1250 Internal MAC RJ45"
PID:                   , VID:    , SN:
NAME: "PA Slot 1", DESCR: "PA Slot Container"
PID:                   , VID:    , SN:
NAME: "PA Slot 2", DESCR: "PA Slot Container"
PID:                   , VID:    , SN:
NAME: "PA Slot 3", DESCR: "PA Slot Container"
PID:                   , VID:    , SN:
NAME: "PA Slot 4", DESCR: "PA Slot Container"
PID:                   , VID:    , SN:
NAME: "module 4", DESCR: "FastEthernet"
PID: PA-FE-TX          , VID:    , SN: 24480039
NAME: "FastEthernet4/0", DESCR: "DEC21140A"
PID:                   , VID:    , SN:
NAME: "PA Slot 5", DESCR: "PA Slot Container"
PID:                   , VID:    , SN:
NAME: "module 5", DESCR: "FastEthernet"
PID: PA-FE-TX          , VID:    , SN: 14203387
NAME: "FastEthernet5/0", DESCR: "DEC21140A"
PID:                   , VID:    , SN:
NAME: "PA Slot 6", DESCR: "PA Slot Container"
PID:                   , VID:    , SN:
NAME: "module 6", DESCR: "ATM WAN DS3 Port Adaptor"
PID: PA-A3-T3=         , VID:    , SN: 29560306
NAME: "ATM6/0", DESCR: "ENHANCED ATM PA"
PID:                   , VID:    , SN:
NAME: "PEM 0", DESCR: "Power Supply Container"
PID:                   , VID:    , SN:
NAME: "Power Supply 1", DESCR: "Cisco 7200 AC Power Supply"
PID: PWR-7200-AC       , VID:    , SN:
NAME: "PEM 1", DESCR: "Power Supply Container"
PID:                   , VID:    , SN:
NAME: "Power Supply 2", DESCR: "Cisco 7200 AC Power Supply"
joedavis123
For what it's worth, we have a 7204VXR with a PA-GE installed, although it also has a NPE-G1 as well.  The maximum throughput we get is about 200Mbps.
http://www9.cisco.com/en/US/products/hw/routers/ps341/products_tech_note09186a00800c814a.shtml has a section about PA-GE, although I'm not sure whether the 200Mbps bandwidth they state is dependent on the NPE-G1.
