07-06-2010 02:29 PM - edited 03-10-2019 05:14 PM
We have some routers that are currently set up for local logon and I want them to use RADIUS authentication like our other Cisco devices. I want the users that access these routers now to still have access to them but not to the other Cisco devices using RADIUS authentication on the network. How can I do this?
Thanks.
07-07-2010 01:58 AM
Thanks.
Are you doing via ACS if yes you can make restriction under user setting for particular access for certain devices like on port ssh or telnet by mentioning the aaa client ip address to have access or block.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
07-07-2010 12:32 PM
We are not using ACS.
Even if I could just enable the routers to allow authentication by RADIUS and local just on these routers that would work but I have not found a way to do that. It always won't authenticate to local when the RADIUS server is up.
07-08-2010 01:58 AM
Pls share the aaa confguration which you have configured in your router !!
Ganesh.H
07-08-2010 06:08 AM
aaa new-model
aaa authentication login default group radius local
aaa authentication login CONSOLE line
aaa authorization exec default group radius if-authenticated
aaa session-id common
07-19-2010 01:27 PM
Does anyone know how to do this?
