Anyconnect VPN - Portal Not Loading - Cisco 871
Jul 6th, 2010
I've got a problem and some questions about a test router I'm setting up in the lab.
I'm just trying to get Anyconnect VPN to work, and I've really been running around in circles trying to figure the bugger out - there is a huge amount of at least partially conflicting information out there, no doubt because of the 871.
I'm using IOS version 12.4(24)T, with sslclient-win-1.1.4.179-anyconnect.pkg as my SSL client. I have no idea if it's the right one, but CCP accepted it.
I recall setting up Anyconnect once before, and the filename was most certainly different. Am I using the right one? It seems to me that there's at least three types of "Client VPN" that Cisco's can do. They are:
SSLVPN
SSL VPN SVC
Anyconnect SSL VPN
Or something like that. I've seen such an assortment, that I'm not sure what's what. What is the difference between them, especially as far as Anyconnect is concerned?
What's up with that "SVC" designation? A few guides I've seen have mentioned it specifically.
Ok, moving on to my troubles.
The problem I'm having right now is when I browse to the VPN page, I get a blank screen that's "Done". Am I correct in thinking I've missed a setting somewhere, or is it perhaps related to the anyconnect package I'm using?
Here's my running-config:
Current configuration : 4618 bytes
version 12.4
no service pad
hostname Cisco871
boot-start-marker
boot-end-marker
logging message-counter syslog
no logging buffered
enable secret 5 $1$OTpa$smj0mTouZOMp01yDNwW1W0
enable password hidden
aaa new-model
aaa authentication login sslvpn local
aaa session-id common
crypto pki trustpoint MyCert
enrollment selfsigned
serial-number
revocation-check crl
crypto pki certificate chain MyCert
certificate self-signed 02
blah numbers blah
        quit
dot11 syslog
ip source-route
ip dhcp pool vpnpool
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   dns-server 208.67.222.222 208.67.220.220
   lease 28
ip cef
no ip domain lookup
ip domain name domain.com
no ipv6 cef
username blargle privilege 15 password 0 blargle
archive
log config
  hidekeys
ip ssh version 2
interface Loopback1
description SSL DHCP Pool Gateway Address
ip address 192.168.250.1 255.255.255.0
interface Loopback2
description SSL VPN Website Address
ip address 10.10.10.1 255.255.255.0
interface FastEthernet0
interface FastEthernet1
shutdown
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface FastEthernet4
ip address 10.1.70.5 255.255.255.0
duplex auto
speed auto
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Vlan2
no ip address
ip local pool sslvpnpool 192.168.250.2 192.168.250.100
ip default-gateway 10.1.70.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.1.70.1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 10.10.10.1 443 interface FastEthernet0 443
ip nat inside source static tcp 10.10.10.1 80 interface FastEthernet0 80
ip access-list extended INTERNET_ACL
remark Used with CBAC(?)
permit icmp any any unreachable
permit icmp any any packet-too-big
permit icmp any any time-exceeded
permit tcp any any eq 443 www
deny   ip any any log
ip access-list extended VTY_ACL
permit ip 192.168.0.0 0.0.0.255 any
deny   ip any any log
access-list 1 permit 192.168.0.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
password 8letters
transport input telnet ssh
scheduler max-task-time 5000
webvpn gateway MyGateway
ip address 10.10.10.1 port 443
http-redirect port 80
ssl trustpoint MyCert
inservice
webvpn install svc flash:/webvpn/svc_1.pkg sequence 1
webvpn context SecureMeContext
title "My Wintastic VPN Service"
ssl authenticate verify all
login-message "Welcome to the VPN. It's tasty!"
policy group MyDefaultPolicy
   functions svc-enabled
   svc address-pool "sslvpnpool"
   svc keep-client-installed
default-group-policy MyDefaultPolicy
aaa authentication list sslvpn
gateway MyGateway domain testvpn
max-users 100
inservice
end
Thar she blows.
This is the guide I used to create the setup:
I've got this sample config now:
I'm prepared to try it next, but my concerns about the client package are putting things on hold. Can the 871 even do this sort of thing? I see things for the other types of SSL VPN, but no one has mentioned Anyconnect. I assume they are similar, however.
Finally, I can't use CCP to configure the VPN - it gives me a message about not supporting the self-signed cert, and I can't even start the process through the GUI unless that is resolved. Is that supposed to happen?
Thanks for your assistance!
redlazer420 Tue, 07/06/2010 - 16:33
So, it turns out I was entering the URL wrong. Glad I caught that one.
In any case, I got this message once I logged in:
The installer was not able to start the Cisco SSL VPN Client.
I got an IP address from my pool, but the software very clearly failed to install. Is it possible there is a conflict with an already installed version? Is there some specific logging settings I should enable?
Once again, thanks for your time.
elviscardin Wed, 07/07/2010 - 06:00
Yes, there is a conflict with a software that is already installed on your PC. Unsinstall any such applications and try again.
Also note that you need to figure out the correct vpn client package for the IOS running on the router and the OS on the PC.
redlazer420 Wed, 07/07/2010 - 12:35
I removed the Anyconnect software already installed on my computer, and I am having the same problem, although it seems like I've made it further than before.
I see that the page is titled "No Support". I imagine this means I'm using the wrong Anyconnect client, but in that case, which one should I be using? Does any Anyconnect client (that's for my OS) work, or do I need a specific version for the 871, like a IOS version or something?
Basically, am I getting the "No Support" because my computer is incompatible with the Anyconnect client it's using, or because the Cisco isn't compatible with the version of Anyconnect on it?
elviscardin Sun, 07/18/2010 - 22:31
The anyconnect client that you are using is slightly old. Why dont you try a later version like 2.4 or 2.5?
What OS are you using on your anyclient host?
