07-06-2010 04:21 PM - edited 03-19-2019 01:12 AM
Several people are able to login to the same group voice mailbox as intended. The problem is that if they do it simultaneously, and listen to the same message, two or more people end up following up on the same item. Is there a setting that deals with this in some way? Perhaps allowing only one person to log in at a time? Or only allows a single user to listen to a single message at a time?
Solved! Go to Solution.
07-06-2010 06:47 PM
You should consider the following:
You can use the dispatch message feature to send a message to a distribution list (from either a call handler or interview handler). The message is configured such that only one user in the group needs to act on the message. When listening to a dispatch message, users are given the option to accept, postpone, or decline the message.
Dispatch messages are handled as follows:
•If a user chooses to accept the message, all other copies of the message are removed from the mailboxes of the other members of the distribution list, regardless of whether the other users have listened to and postponed the message.
•If a user chooses to postpone the message, it remains as an unread message in the mailbox of that user and in the mailboxes of the other members of the distribution list.
•If the user chooses to decline the message, it is removed from the mailbox of that user, but copies of the message remain as unread in the mailboxes of the other members of the distribution list.
•If there is only one copy of the dispatch message remaining, and no user has yet chosen to accept the message, the final user whose mailbox it is in must accept it. That user is not given the option to decline the message.
Dispatch messaging is useful in situations where a team is available to respond to issues, but only one member of the team needs to respond. For example, an IT department may want to set up a call handler to take messages from employees who need assistance, and then send the messages as dispatch messages to a distribution list comprised of IT department staff. All of the members of the distribution list receive a copy of each message. Team members can then decide whether to accept or decline a message; declined messages are then picked up by other team members.
For more info, go here: http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/administration/guide/7xcucsag170.html#Dispatch_Messages
That should provide the functionality you're looking for where only one user is responsible for following up on a message.
Hailey
Please rate helpful posts!
07-06-2010 06:47 PM
Hailey
07-06-2010 07:14 PM
Great! Thanks.
