Problem with 1841
Answered Question
Jul 6th, 2010
I m having a problem with my cisco 1841.
From the router i can ping external ip(4.2.2.2 or 187.103.200.1). but a user from vlan 11 can ping router wan interface 187.103.200.2 and default gw 172.25.11.1, but can't ping external ip.
Correct Answer by Chetan Kumar Ress about 6 years 7 months ago
Hi Vitor
Can you remove ip nat inside from Physical interface & configure the same one under all subinteface.
Can you post output of sh ver (IOS Ver.)
Chetan Kumar
Overall Rating: 3.3 (3 ratings)
Reza Sharifi Tue, 07/06/2010 - 18:40
Hi Vitor,
Looking at your config,  is vlan 11 supposed be actually a /30 subnet or is it a typo?
interface FastEthernet0/1.11
description qi
encapsulation dot1Q 11
ip address 172.25.11.1 255.255.255.252
Reza
vitorssouza Tue, 07/06/2010 - 19:53
Reza,
it is right, because for this vlan there is only 1 valid ip, for the user.
wang baojun Tue, 07/06/2010 - 20:13
Vitor,
the config seem no problem ,you can try done the following operation.
description qi
ip nat inside
Correct Answer
Chetan Kumar Ress Wed, 07/07/2010 - 12:07
Hi Vitor
Chetan Kumar
