Reza Sharifi Tue, 07/06/2010 - 18:33
  • Cisco Designated VIP,
    2017 LAN
Hi Luis,
This command is mostly used when you are deploying PBR.
The set ip next-hop command verifies the existence of the next hop specified, and…
  • if the next hop exists in the routing table, then the command policy routes the packet to the next hop.
  • if the next hop does not exist in the routing table, the command uses the normal routing table to forward the packet.
Have a look at this document for more info:
http://www.cisco.com/en/US/tech/tk364/technologies_configuration_example09186a00801f3b54.shtml#casetwo
Reza
