Question on Activating and Deactivating Zonesets
Jul 6th, 2010
  • I have deleted some zones in a zoneset
  • These zones do not show up in the running config but they are there if you show active zones on this vsan
  • The only way that I know of is to deactivate the zoneset
  • But deactivating zoneset puts all the existing zones to drop traffic.
PS: all zones are in the same VSAN ans same ZONESET
Is there any other way to delete the zones permanently other than deactivating the zoneset?
blueyonderguy Tue, 07/06/2010 - 21:15
if you want to get rid of them then
- save your running config
- update the zoneset config by removing each unwanted zone from the active zoneset (no member...)
- delete each unwanted zone (no zone name ... )
- activate the zoneset again
- verify that the host connectivity is not affected
you dont have to deactivate a zoneset to delete zones out of it
skumar7193 Wed, 07/07/2010 - 07:00
Thank you for your quick reply. I guess then we ONLY execute the "no zoneset activate name zsname vsan vsanId" when there are no more active zones left.
Trending Topics: Storage Networking
