TFTP 'state' failing
Jul 6th, 2010
Hi all,
We are running a PIX 515e with  Cisco PIX Security Appliance Software Version 8.0(4). When running TFTP session through the firewall the firewall doesn't recognise the return traffic as part of the TFTP connection.  I understand how the TFTP  protocol works so I don't need any info on that but has anyone else experienced this.  Is there a particular setting that needs to be enabled or is there a work-around?
Cheers
Overall Rating: 5 (1 ratings)
Jennifer Halim Tue, 07/06/2010 - 22:49
  • Cisco Employee,
Yes, you can enable "inspect tftp" under your global_policy and that would allow the return tftp traffic.
Hope that helps.
neil_titchener Wed, 07/07/2010 - 20:46
Thanks for the quick reply.  Where would I find Global-policy in ASDM 6
.1?  I've checked the Inspect Maps but there isn't one for tftp.
Cheers
Jennifer Halim Wed, 07/07/2010 - 21:09
  • Cisco Employee,
From ASDM:
Configuration --> Firewall --> Service Policy Rules --> highlight inspection_default --> click Edit --> Rule Actions tab --> scroll down and tick/enable TFTP
Hope that helps.
Related Content
