Old 4006 power question
Jul 6th, 2010
I have an old 4006 running catOS, I was playing with the power redundancy and noticed the following....
If I pull the power from  PS-1, and do a "show env pow", I see a fault alarm on PS1 (as expected) bu also a fan alarm on ps-3, but the fan on PS3 is OK.
If I reconnect PS-1, the PS1 fault alarm clears and the PS3 fan alarm clears.
Has anyone seen this before?
I'd appreciate any pointers.
Chris
Console> (enable) show env pow
PS1-Type          PS2-Type          PS3-Type
WS-X4008          WS-X4008          WS-X4008
PS1-Status PS2-Status PS3-Status PEM Installed PEM Powered
ok         ok         ok         no           no
Power Budget is : 2 supplies
                    Total (Watts) Drawn (Watts) Remain (Watts)
System Power ( 12V)           750           460           290
Inline Power ( 51V)             0             0             0
Configured Default Inline Power allocation per port: 15.400 Watts (0.301 Amps)
Console> (enable)
Console> (enable) 2010 Jul 06 23:03:43 %SYS-2-PS_FAIL:
Power supply 1 failed
faulty     ok         ok         no           no
Console> (enable) show env pow2010 Jul 06 23:03:58 %SYS-2-PS_NFANFAIL:
Power supply 1 failed or was turned off
show env pow
faulty     ok         fan failed no           no
Console> (enable) 2010 Jul 06 23:04:14 %SYS-2-PS_FAIL:Power supply 1 failed
2010 Jul 06 23:04:19 %SYS-2-PS_OK:Power supply 1 okay
show env pow
ok         ok         ok         no           no
Console> (enable)
chris parkinson Thu, 07/08/2010 - 14:13
Fixed, it was the software.
I rolled back to an older image and the problem disapeared.
