class value in label
Jul 7th, 2010
Hi Guys,
  Came across some doc for DSCP on MPLs which states label can carry class values and  mpls EXP bits carry drop value. If thats the case how can i see the class value in label and here are they mentioning 20 bits label? And is there any pre-defined values DSCP to EXP  values?
V Dinesh Kumar
shivlu jain Wed, 07/07/2010 - 11:00
  • Silver, 250 points or more
In MPLS we are having only 3 bit which means not more than 8 combinations of offering class of service. If you want to map DSCP to MPLS QOS then you can imagine mappings will like 0-7 DSCP belongs to MPLS EXP bit 1 then 8 to 15 DSCO belongs to 2 and upto 64.
regards
shivlu jain
http://www.mplsvpn.info
inderdeeps Tue, 07/20/2010 - 01:37
Hello Dinesh,
We have specific combination of the 3 bits in EXP, For there combination we have the DSCP range from 0 to 63.We are defining the Class of the label as follows:-
Code Point
Forwarding Class
Loss Priority
000
best-effort
low
001
best-effort
high
010
expedited-forwarding
low
011
high
100
assured-forwarding
low
101
assured-forwarding
high
110
network-control
low
111
network-control
high
But in actual the Diffserv model uses 6 bits of IP tos value to define the Diffserv code points(DSCP) which distinguishes how packet can be treated by the network. The first 3 bits are of EXP bits and the other 3 bits are provided by the Service Provider named as IP prec Bits, so we have two modes now:-
  • Default A  simple best-effort class, with a DSCP value of 000000. Packets with no  defined DSCP are mapped to the default class for best-effort service.
  • Class  Selector Provides for backward compatibility with 3-bit IP PREC  classes. Basically, it defines a DCSP of XXX000,  where XXX represent the PREC bits.
For further, Pls go through the below link:-
http://www.atslog.dp.ua/ch04lev1sec5.html
Cheers!!!
Inderdeep
Giuseppe Larosa Wed, 07/21/2010 - 13:14
  • Hall of Fame,
    Founding Member
Hello Dinesh,
you are probably referring to E LSPs versus L LSPs idea
to be able to map the 6 bits wide DSCP you need to use multiple LSPs with the same destination
see the following document from networkers 2008
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6557/ps6607/prod_presentation0900aecd8031280f.pdf
silde 6
Hope to help
Giuseppe
