Using BRI interface on NM-4B-S/T
Jul 7th, 2010
Hi all,
I've got a Cisco 2821 with
2 x VWIC-2MFT-T1/E1 (slot0/subslot0 - slot0/subslot1)
1x NM-4B-S/T (slot1)
I want my fax server (connected to the BRI1/0 on the NM-4B-S/T) to communicate with PSTN through gateway and CUCM6.1.3.
Cisco 2821 registered in MGCP in the CUCM for the E1 access, registered in H323 for the BRI interface.
I configured the following on my gateway (for outgoing call from the BRI interface)
dial-peer voice 2 voip
destination-pattern .T
session target ipv4:10.XX.XX.XX
How can I do for incoming calls (fax), except route list in the CUCM to route calls from E1 access to the H323 gateway.
I can not configure dial peer pots because there are no voice port with the NM-4B-S/T.
Thanks a lot for your help.
Overall Rating: 5 (2 ratings)
ttortelier Sat, 07/10/2010 - 09:46
Ok, thank you for your answer, but, to what extend can I use this card?
Paolo Bevilacqua Sat, 07/10/2010 - 16:19
It can be used for data calls only.
Please remember to rate useful posts clicking on the stars below.
