CDAUI2030 Invalid IMAP Server settings
Answered Question
Jul 7th, 2010
Hi all,
I am following the "Cisco CAD installation Guide: Configuring Microsoft Exchange for Agent E-Mail"
and trying to set the Agent E-Mail Settings > Global Settings in Cisco Desktop Administrator
but it comes up with an error:
Then i found that the Cisco website has mentioned that there is a bug for this error:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsz97295&from=summary
and i followed the workaround steps, but the error still exists
Any body can help ?? Thanks!
The envirnoment
UCCX 7.0(1)SR05_Build504
Windows 2003 service pack 2
Exhcange 2003 service pack 2
Sam
Correct Answer by Tanner Ezell about 6 years 10 months ago
UCCX's Agent Email feature does not work AT ALL with any kind of
encryption on the IMAP and SMTP connectors. It's best to simply create
a new virtual connector with absolutely no TLS/SSL/encryption of any
kind and use that.
If you are unwilling or unable to do that or it still doesn't work
with a new virtual connector, post screen shots of the IMAP connector
and how it's configured in Exchange.
On Wed, Jul 7, 2010 at 5:39 AM, samhopealpha
Overall Rating: 5 (1 ratings)
Correct Answer
Tanner Ezell Wed, 07/07/2010 - 05:39
  • Silver, 250 points or more
kind and use that.
samhopealpha Mon, 07/19/2010 - 19:26
Thank you ~! after i removed the TLS/SSL part~ the connection works fine now ~~
Sheraz Saeed Lodhi Thu, 05/05/2011 - 00:19
I am facing the same issue and using UCCX 8.0.x. I have confirmed the excahge server settings with Excahange Admisnirator and they are not using any TLS/SSL/encryption at all. What could be the issue any help would be great.
By the way we are tryting to link with IBM Domino although we know this is not supported by cisco but as its has IMAP4 which is required for Agent E-mail configuration.
Related Content
