Unable to change pourcentage allocation csq for outbound call
p-siadoua
hi,
I am trying to configure  outbound call on customer  uccx 7.1 SR4, we need to change the allocation csq. The  pourcentage still keep the default configuration (10%) we need to change  it but it does not work.
best regard
Aaron Harrison
You need to do it like this:
1) CLick on a CSQ name in the 'Assigned CSQs' box
2) set the percentage to what you like
3) Click update
Then repeat for each CSQ that you wish to modify - it's set per-CSQ so you can have different percentages for each one. Confusing the first time you do it...
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
3) Click update
Aaron
i have done the update after the change of pourcentage CSQ.  But it really doesn't work.
regards
Sorry,
i misunderstand your post, i have tried again  and select the csq  and it work.  thank for your help.
Best regards
pamela
No problem!
