RTMT Perfmon for SIP trunks
Jul 7th, 2010
I have several SIP trunks across a few subscribers and when I go to monitor Sip calls active I can see all but 1 of the SIP trunks. If I do a device search for all SIP trunks I can find it. when I try to add the counter instance I can find the others but not that one, it is configured in a very similiar way to a trunk that is shoeing on there?
using Call Manager 6.1
Anyone have any ideas why it may not be showing up? The trunk itself is working fine.
Overall Rating: 5 (1 ratings)
dual_line Mon, 02/21/2011 - 06:35
Seeing as nobody has answered this one here's one solution.
I experienced the same issue today. I resolved it by restarting the following services in the following order on the affected servers:-
Cisco RIS Data Collector
Cisco RTMT Reporter servlet
Cisco CallManager
Once restarted my RTMT session cleared an error message that stated 'RisDC service stopped to monitor the following counters :\\CM_IP\Cisco SIP(Trunk name)\CallsActive'
Hope this helps somebody..
