LMS 3.2 server - low disk space error
Jul 7th, 2010
We have 250GB of hard disk and it is almost used by CSCopx folder.
Please suggest what would be a good action plan to reduce this size.
Guru
Joel Monge Wed, 07/07/2010 - 08:19
  • Cisco Employee,
Probably most space is being consumed by CSCOpx\log.  To quickly cleanup some logs, you can manuall run the command:
logrot_trunc c:\Progra~1\CSCOpx\log\syslog.log
Assuming this is the correct path on your server.  You can also schedule log rotation to occur on a regular basis to avoid the logs growing past a certain point.  This can be scheduled under Common Services > Server > Admin > Log Rotation.
Might also be a good idea to check if you have debugging turned on under the various modules in LMS to decrease the speed of the log growth by setting the logging to a lower level.
Related Content
