sewillar Wed, 07/27/2011 - 13:46
Hi Eslam,
If I understand correctly, you are looking to place your devices under a Service Contract for support?
If so, you would need to use the Cisco Partner Locator located at:
http://tools.cisco.com/WWChannels/LOCATR/openBasicSearch.do
You could perform a Google Search, like the following link:
http://www.google.com/#sclient=psy&hl=en&source=hp&q=Cisco+851W+Contract&aq=f&aqi=&aql=&oq=&pbx=1&bav=on.2,or.r_gc.r_pw.&fp=984b534b048f1d79&biw=1280&bih=827&safe=active
Either way you can usually find one. Notable Ones are Ingram Micro, CDW, or INXI. Some only deal with larger businesses. But either way you can generally locate one close to you.
