PVLAN between C375O & firewall
I'm looking for a solution to configure PVLAN on a trunked link between a C3750 and a juniper with IP addressing configured on subinterfaces. The subinterface on the Juniper is the default gateway of the PVLAN. Is it possible to configure the trunked port in promiscuous mode for certain vlans?
Because I didn't found a solution for this, a workaround was found by configuring the default gateway on the C3750 and configure the interface vlan in promiscuous mode. A seperate vlan with no pvlan configuration is connecting the Juniper with the 3750. This way a trunk remains between the Juniper and the 3750 to carry several vlans. Is this a good solution? Any suggestions are welcome.
regards
Lode
