Werid Issue
Answered Question
Jul 7th, 2010
so far on 3 of the my device it will stop optimizing and when i login i get this
Cisco Wide Area Application Engine
WAE-0370-574 login: admin
Password:
No directory /local/local1!
Logging in with home = "/".
System Initialization Finished.
Disk based software not installed.
Some applications may not run correctly!
WAE-0370-574#
it appears like everthing has been deleted from flash
WAE-0370-574#dir
      size          time of last change             name
WAE-0370-574#
Even when I reload the image nothing....
WAE-0370-574#sh flash
Your software installation appears to be incomplete.
(could not access /sw/UP-TO-DATE or /swstore/manifest)
Please run 'copy ftp/cdrom install' to install a new image.
System image on flash:
Version: 4.1.5f.b2
System flash directory:
System image: 185 sectors
Bootloader, rescue image, and other reserved areas: 41 sectors
256 sectors total, 30 sectors free.
WAE-0370-574#
Enterprise     active      07/07/2010      admin
Video          not active
Virtual-Blade  not active
WAE-0370-574#
WAE-0370-574#sh accelerator
Accelerator     Licensed        Config State    Operational State
cifs            Yes             Enabled         Shutdown
epm             Yes             Enabled         Shutdown
http            Yes             Enabled         Shutdown
mapi            Yes             Enabled         Shutdown
nfs             Yes             Enabled         Shutdown
ssl             Yes             Enabled         Shutdown
video           No              Enabled         Shutdown
wafs-core       Yes             Disabled        Shutdown
wafs-edge       Yes             Disabled        Shutdown
WAE-0370-574#
Any suggestions ?
Correct Answer by Michael Korenbaum about 6 years 6 months ago
The message your receive during login indicates either a failed upgrade/install of WAAS software or hard disk failure(s).  Right now this device isn't running WAAS from disk as it should (it's running a limited version off of flash), and as such will not optimize traffic.
The first step to resolve this would be to re-install the software bin image (copy ftp install )
After the reload to complete the install issue the command show disk details to view the health of the disks.
Cheers,
Mike Korenbaum
Cisco WAAS PDI Help Desk
http://www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Michael Korenbaum Wed, 07/07/2010 - 06:20
Cheers,
Mike Korenbaum
